emails with attachments keep sending... HELP!!!
papadingo
Hi.. HELP!!!
I've adjusted the timeout, but it happened AGAIN.. Outlook 2007 enterprise.. the attachment was only 3 or 4 meg...
It has now caused the server I was going through to be blacklisted.. getting that sorted out, but what else could be causing this?? :confused:
Very frustrating when I am sending to prospective clients.. :mad:
thanks
Peter G.
thanks.. I'm using PCTOOLS internet security.. outlook shut down the add-in quite a while ago, and I never put it back.. INTELLIGUARD was set to scan emails on receipt as well as when sending.. I've turned that off now just now.. fingers crossed.. thanks for the hint to search there again... :)
Is there anything else I should be checking into?
You can check to see if it happens in Safe mode but the usual cause is a scanner taking too long to scan the message and Outlook doesn't get confirmation back from the server that it accepted the message, so it tries again. Larger messages are more likely to be affected because it takes the scanner longer to scan and send.
If the antivirus is doing its job, you won't be infected, so no need to scan outgoing mail. I wouldn't scan incoming either - if you happen to open an infected message, the scanner will pick it up then. Chances are that everything the scanner id's as infected is something you knew was bad news anyway.
Thank you for that Diane. Sounds logical to me.. Have stopped outgoing check, but afraid to test it.. Seems to be a random thing. I agree about the first incoming as well.. Will disable that as well.
T Emails with attachments from an alias are undeliverable to one of three aliases Using Outlook 2
A Gibberish Titles & Attachments @ incoming Outlook 2013 emails Using Outlook 1
V Intermittantly not sending emails with attachments Using Outlook 4
W Outlook not decoding emails/attachments Using Outlook 0
D Saving outlook emails in html and attachments Using Outlook 4
O Exchange 2003 displaying HTML emails as having attachments Exchange Server Administration 7
S Automate saving of attachments on new incoming emails Outlook VBA and Custom Forms 3
V Move old emails or emails with large attachments ? Outlook VBA and Custom Forms 1
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
J Action based on number of emails after sort by from Using Outlook 3
D Can't read some emails - text size too small. Using Outlook 2
R How to use VB .Net to send emails? Outlook VBA and Custom Forms 0
T Outlook is categorizing emails incorrectly Using Outlook 0
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
D Delete Outlook emails from MS server Using Outlook 20
A Flagged Emails highlighted in yellow Using Outlook 3
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
J gmail and deleted emails. Using Outlook 0
U Outlook not responding when trying to print Emails Using Outlook 6
