Intermittantly not sending emails with attachments
Vincenzo
Outlook 2021 64 bit
My friend's Windows 7 computer running Outlook 2013 is intermittently not sending emails that have attachments. The emails remain in the Outbox. It seems to possibly be more prevalent when the attachment is above 1 MB.
When I see the email sitting in the Outbox, if I click Send/Receive, I get a message saying the connection to the server was interrupted, with a code that ends in 800CCCF I think. (The message only appears for about half a second then disappears).
Another computer that is on the same router, running Windows 7 and Outlook 2010, can send attachments without any problems when the first computer is having the failure.
I checked the internet connection by running speedtests, it seems ok other than the fact that the upload speed seems very high, 30Mbs.
The email is through GoDaddy pop, ISP is Cox.
Does it work in Safe mode? Are any non-Microsoft addins installed? Is there an antivirus scanner scanning outgoing mail?
http://www.slipstick.com/problems/common-outlook-smtp-errors/
- - - Updated - - -
I am just getting back to you on this because I was not sure if the fixes I did per your suggestions had solved the issue.
(Even though this is the same computer as the other post I did today about duplicate emails in Inbox, I suspect they may be different issues since she tells me the duplicates/triplicates only happened once or twice.)
I had previously disabled the following add ins on my friend's computer after reading your last post: icloud, iTunes, Norton AntiSpam. I also disabled Norton scan of outgoing email. But today she called and said messages stuck in outbox was happening again.
I logged in and saw an email stuck in her outbox, it had an 11 GB attachment. She uses godaddy, I checked and they allow up to 20 GB attachments, max per message of 30 GB. So she should be ok there.
I deleted the email, then I resent the same email with the same attachment. It went out fine. Then I sent it again and it went out ok.
I tried a third time and it got stuck in Outbox. Outlook also gave an error at that time:
0X800CCC0F Connection to server was interrupted
The 4th attempt went out ok.
The 5th attempt got stuck in outbox, same error message.
So it is an intermittent problem.
Any ideas?
Another email with just a 4 MB attachment is stuck in the Outbook, and giving the same error as above. So I guess the size of the other attachment was not really the issue.
This: 0X800CCC0F Connection to server was interrupted usually means there is a problem with the connection - godaddy could be dropping it, it could be a bad link between her computer and godaddy.
Does it work without issue in Safe mode? If so, then the problem is with something in outlook. (I know, it's hard to repro when it is intermittent.)
The crash could be related to this error.
R File not found when sending email with attached pdf file Using Outlook 2
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
D Prompt to prefix subject line whenever sending an email Outlook VBA and Custom Forms 3
P default font when sending email from browser Using Outlook 1
M Messages Intermittently Dont Arrive In Sent Items After Sending Successfully Using Outlook 4
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
V Form data not sending for some users Outlook VBA and Custom Forms 2
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
D Sending email from Office 365 alias in Outlook Using Outlook 3
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
R Warn before sending message Outlook VBA and Custom Forms 4
HarvMan Hotmail - Sending email is undeliverable Using Outlook 4
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M McAllister Outlook stops Sending/Receiving/Synching after disconnecting remote desktop session Using Outlook 2
B When sending an email, I am showing 2 of my address's Using Outlook 1
A Check for words in subject header before sending email Outlook VBA and Custom Forms 4
W Sending To Wrong Account Using Outlook 15
H Select Specific Account When Sending Email, Based on Current Folder Outlook VBA and Custom Forms 1
M MsgBox when not sending from specified account Outlook VBA and Custom Forms 2
R Sending emails via Outlook XP, from Windows 10 File Explorer Using Outlook 1
L Creating drafts when I thought I was sending Using Outlook 1
C address book "when sending email" bug? Using Outlook 0
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
A Sending Emails Through Outlook From Multiple Email Addresses Using Outlook 1
P Outlook 365 sending intermittently Using Outlook 0
C How to avoid sending mail to the wrong contact person Using Outlook 1
V iCloud Calendar invitations not sending Using Outlook 3
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
latitudeit Outlook for Android - Sending from an alias address Using Outlook 2
A How to get rid of "sending on behalf of" when sending from Outlook 2016 client Using Outlook 12
Diane Poremsky Automatically create a task when sending a message Using Outlook 0
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
Diane Poremsky Outlook is sending winmail.dat attachments Using Outlook 0
