button to send and print emails
Yes, I did, but got side tracked with end-of-summer stuff. :( It is a limitation when using code to print. Email doesn't have pages so the length is determined by the printer driver but vba hooks in to the process after that point. It can count the pages as it prints but not calculate the total.
Thanks for your reply. Too bad it works that way.
Do you know of a way to set the Print Style using vba? I'm wondering if I could set up another print style that doesn't refer to the total pages for when I print using code, and have the code use that print style automatically.
The problem is the print stuff is not exposed in the object model and you need to use the shell. I believe the settings are in the registry, so you could change it using code.
There is a program called regshot that can read the registry before you make a change then read it after and compare - that will get the key and values that need changed.
Took me a little time to look into this, but I found the key and values.
HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Outlook\Printing\PrintTypesDefault\100: 0x0000000C
HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Outlook\Printing\PrintTypesDefault\100: 0x0000000D
Is there an easy way to switch the value of the registry key to 0x0000000D before the Item.PrintOut command and back to 0x0000000C afterwards?
Sub SendPrint()
Dim obj
Dim oCategory As Outlook.Category
Set obj = ActiveInspector.CurrentItem
obj.Categories = "Print"
obj.Send
   If TypeOf Item Is Outlook.MailItem And Item.Categories = "Print" Then
       Item.PrintOut
I think this might work, but I can't test it at home; I'll check tomorrow at work. Can you let me know if you see anything obviously wrong with it?
       Set myWS = CreateObject("WScript.Shell")
       myWS.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Outlook\Printing\PrintTypesDefault\100", "0x0000000D", REG_DWORD
       Item.PrintOut
       myWS.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\14.0\Outlook\Printing\PrintTypesDefault\100", "0x0000000C", REG_DWORD
It looks good to me - it's pretty much what I would have suggested. Except its erroring on the regwrite lines (I put the set line + one regwrite line in a macro to test it.) . The REG_DWORD part is the problem, it works if it remove it (but saves the wrong kind of key.)
I can't believe I didn't notice it sooner - you don't use 0x0000000D, you use the number behind it, in the brackets.
myWS.RegWrite "HKEY_CURRENT_USER\Software\Microsoft\Office\15.0\Outlook\Printing\PrintTypesDefault\100", "13", "REG_DWORD"
Thanks! I also had to define myWS (add Dim myWS As Object), but after that it worked like a charm.
Thanks so much for your help!
J Send and Receive Button - only check default account? Using Outlook 1
A custom send button Outlook VBA and Custom Forms 3
H Preventing the Send button from being clicked on an Outlook Form Outlook VBA and Custom Forms 1
S Create a custom "Send" Button Outlook VBA and Custom Forms 3
Commodore Button for Send/Received for a specific account Using Outlook 4
M Programatically click the Send button. Outlook VBA and Custom Forms 5
N modify New mesage SEND button Outlook VBA and Custom Forms 1
B Customized Send button Outlook VBA and Custom Forms 5
G Outlook 2007 Meeting Item Send Button Outlook VBA and Custom Forms 10
D Button beside send, but not beside reply Outlook VBA and Custom Forms 2
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 1
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 2
A adding a custom send button? Outlook VBA and Custom Forms 1
C Outlook 365 What happened to the "Today" button? Using Outlook 13
J Hide/Disable the X button on BrowseForFolder Dialog Using Outlook 4
B Please remind me how I added this message button Outlook VBA and Custom Forms 0
J Outlook 2021 ScanPST errors (yet again ... sorry): repair button missing Outlook 2021 Using Outlook 7
jehan2256 "History" button in Business Contact Manager Using Outlook 1
L "Insert Pictures" Button-Wrong Folder Using Outlook 5
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
J "Contact" button in Journal entry Using Outlook 1
Witzker HowTo start a macro with an Button in OL contact form Outlook VBA and Custom Forms 12
N Which Button Was Clicked on the Ribbonbar Menu Outlook VBA and Custom Forms 2
E Can't accept or decline task (no button appears) Using Outlook 2
Witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
A ScanPST finding errors but no Repair button Using Outlook 2
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
