Message not arriving in default accounts Sent Items folder when using Send to
Takasumi
Messages sent via Brother MFC 'scan to email' or Send to --> Mail Recipient arrive in Sent Items folder of shared mailbox and not senders default pop account.
Outlook 2010 client is configured with a pop account and exchange shared mailbox. If I send from the pop account using New E-mail option then messages arrive in the correct Sent Items folder.
The shared mailbox is configured in online mode, this to avoid sync issues when running macros etc. Not not been able to find anything related to this particular problem. Configuring another exchange account with the shared mailbox does not help, it seems that the preference is the Sent Items folder of the shared mailbox. I note that I can see messages via the Outbox of the default account. Been able to replicate behaviour on 2 computers. Can anyone suggest how to resolve please?
Re: Message not arriving in default accounts Sent Items folder when using Send
Is the exchange mailbox a mailbox that several people share or a shared mailbox attached to his own exchange mailbox? (Yes, there is a difference).
I know Exchange accounts always like to be default, so I'm sure its related to that. if the first scenario is correct - a mailbox several people share - then it's "expected behavior" because Exchange thinks its default.
Yes it is a shared exchange based mailbox which is accessed from various users/computers. I set up an exchange mailbox as a test but still the shared mailbox takes precedence??
If I compose and send an email from within outlook then work correctly, only when the 'send to' functionality is used it always places the message in the Sent Items folder of the shared mailbox, but goes out via the outbox of the sending account. From a recpients perspective the message is coming from the correct sender. I find this behaviour most odd and need to resolve it. I enabled logging and did notice an errors in the pst.log but have not been able to work out failures? ---- extract below:
2013/11/20|13:17:51:738|Failed to open the message PC|4|2106276|||||||||0x80040818|FAIL
2013/11/20|13:17:51:738|Unable to get the attachment info - we won't index any attachments for this message|4|2106276|||||||||0x80040818|FAIL
2013/11/20|13:17:53:769|SGO_ScEnsureAttachment done|4|2106276|||||||||0x80040818|FAIL
2013/11/20|13:17:53:769|SGO_ScGetAttachID done|4|2106276|||||||||0x80040818|FAIL
2013/11/20|13:17:53:769|SGO_ScBuildURL done|4|2106276|||||||||0x80040818|FAIL
2013/11/20|13:17:53:769|Failed To Build A URL|4|2106276|||||||||0x80040818|FAIL
2013/11/20|13:17:53:769|OnDataChanged returned an error|4|2106276|Delete||mapi://{S-1-5-21-565356640-2836605809-3901028014-5187}/ron@xxxxx.co.nz($5bc3897a)/0/Outbox/????????????????????????||||||0x80040d06|FAIL
2013/11/20|13:17:53:769|Won't retry for this error|4||||||||||0x80040d06|FAIL
2013/11/20|13:17:53:972|OnIndexStatusChange - Gatherer|4|2106276|Modify||mapi://{S-1-5-21-565356640-2836605809-3901028014-5187}/ron@xxxxx.co.nz($5bc3897a)/0/Outbox/????????????????????????||||||0x80041201|FAIL
2013/11/20|13:17:53:972|Won't retry for this error|4|2106276|||||||||0x80041201|FAIL
2013/11/20|13:17:53:972|Flushing completed doc|4|2106276|Add||||||||0x80040818|FAIL
2013/11/20|13:17:53:972|Flushing completed doc|4|2106276|Modify||||||||0x80040818|FAIL
2013/11/20|13:17:53:972|Flushing completed doc|4|2106276|Modify||mapi://{S-1-5-21-565356640-2836605809-3901028014-5187}/ron@xxxxx.co.nz($5bc3897a)/0/Outbox/????????????????????????||||||0x80041201|FAIL
2013/11/20|13:17:53:972|Flushing completed doc|4|2106276|Delete||mapi://{S-1-5-21-565356640-2836605809-3901028014-5187}/ron@xxxxx.co.nz($5bc3897a)/0/Outbox/????????????????????????||||||0x80040d06|FAIL
thanks
P SPAM message about Comcast email migration to Yahoo Using Outlook 1
P deleted message keeps reappearing10-20-more times Using Outlook 3
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
Terry Sullivan Unwanted Duplicate E-Mails -- One with My Message and the Other Blank Using Outlook 0
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
E "The operation cannot be performed because the message has been changed" Using Outlook 4
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
D Outlook 365 Outlook Message "Cannot be sent because the message has changed" Using Outlook 0
B Please remind me how I added this message button Outlook VBA and Custom Forms 0
E PgUp and PgDn don't work for displayed message content (but do for web pages) Using Outlook 4
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
F Outlook 2019 Forwarding Message and Keeping Unread Status Outlook VBA and Custom Forms 0
A rule name into message - how? Outlook VBA and Custom Forms 5
A Links in email getting error message about group policy Using Outlook 4
Commodore Unable to move message Using Outlook 3
Y Disable Microsoft Outlook Test Message Using Outlook 4
S Unable to change Message Class Outlook VBA and Custom Forms 0
S Changing Message Class Outlook VBA and Custom Forms 4
Cathy Rhone Mail merge error message Using Outlook 1
Cathy Rhone The properties of the message have been changed Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
S Unable to extract text from an Outlook email message Using Outlook 2
R Outlook 2016 Message-ID oddity/inconsistency? Using Outlook 7
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
C must select message to trigger safe list Using Outlook 3
Witzker HowTo Change message Class of contact form Outlook VBA and Custom Forms 0
