Changing Message Class
srmsrm
Outlook 365 64 bit
I'm using Outlook 365, W10, not using Exchange. For below, it uses the the default contacts folder (using the name of my form) to change the message class in the defaults contact folder.
How can I update this to select a different contacts folder that is not the default contacts folder to update the message class.
Sub ChangeMessageClass()
Set olNS = Application.GetNamespace("MAPI")
Set ContactsFolder = olNS.GetDefaultFolder(olFolderContacts)
Set ContactItems = ContactsFolder.Items
For Each itm In ContactItems
If itm.MessageClass = "IPM.Contact" Then
itm.MessageClass = "IPM.Contact.Good News Contact"
itm.Save
Shawn
I got it to work in the current folder, but still seeing if I can select another folder.
Set ContactsFolder = Application.ActiveExplorer.CurrentFolder.Items
For Each Itm In ContactItems
If Itm.MessageClass = "IPM.Contact" Then
Itm.MessageClass = "IPM.Contact.SRM"
Itm.Save
This : Set ContactsFolder = Application.ActiveExplorer.CurrentFolder.Items
Should be just this: Set ContactsFolder = Application.ActiveExplorer.CurrentFolder
Then use this to set the items - Set ContactItems = ContactsFolder.Items
Selecting the folder first and running it is generally the easiest way to do it - but you can hard code a folder by name
Subfolder of contacts: Set ContactsFolder = olNS.GetDefaultFolder(olFolderContacts).folders("folder name")
Same level as Contacts: Set ContactsFolder = olNS.GetDefaultFolder(olFolderContacts).Parent.folders("Folder name")
Diane:
I asked about selecting a folder. What I meant is when I run the Macro I select what folder to use the macro to run on. I don't think I was clear in my question.
I may be misunderstanding your guidance. I tried both versions below and they seem to work the same. They update the message class in the folder I have active (clicked on).
How do they differ and what am I missing?
Shawn
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
T Changing Icon of message class Outlook VBA and Custom Forms 1
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
L changing view settings based on message body Using Outlook 1
C Outlook Changing Sent Message Headings to SPAM =?UTF-8?B?4Liq4Lij4LmJ4L Using Outlook 1
R Changing the default message form in Outlook 2007 Outlook VBA and Custom Forms 1
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
F Auto changing email subject line in bulk Using Outlook 2
K Changing the Deleted Items location in Outlook 2019 Using Outlook 2
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the default *.pst and *.ost sizes Using Outlook 0
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 Using Outlook 0
R The changing way to access information in Office 365 Using Outlook 0
