Changing Icon of message class
Tobias Böhm
here's what I want to do. My AddIn is creating outlook-folders at
runtime. One for mail one for tasks and another one for tasks. The
items of the last task folder should have a different icon (can be one
of the available outlook-icons).
I found
http://groups.google.com/group/micr...lnk=gst&q=message+class+icon#57d7d93a561a3a07
and did what Sue Mosher suggested. I created a Form, published it,
changed the MessageClass of an item, which then used the new form but
the icon didn't change. Furthermore, the MessageClass of that item was
reset after restarting outlook.
I fifured that I had to change the default class items in that folder
get when created. Also I can't change the Default message class of a
folder. I can change the PR_DEF_MSG_CLASS property via MAPI which
according to OutlookSpy works. But OutlookSpy also says that the
DefaultMessageClass property of the TaskITem property hasn't changed.
I think I'm missing something here. What is the simplest way to
achieve what I want to achieve?
Tobi
K
Ken Slovak - [MVP - Outlook]
When you publish a form of any base MessageClass it will use the Post icon
unless you explicitly change the icon in the Properties tab of the form when
it's in design mode. You need to change both the large and small icons for
that new custom MessageClass before you publish the form. At that time you
also should set the Version string property and increment or change it for
every published change you make to the form to avoid forms cache corruption.
After that any item that uses that custom MessageClass will use the icons
you set for that MessageClass.
The default class of a folder is always an intrinsic Outlook item type, such
as PR_CONTAINER_CLASS == IPF.Task for all task type folders.
The PR_DEF_POST_MSGCLASS property can be changed to alter what MessageClass
is used when a new item is created in that folder. That has a property tag
of 0x36E5001E or in DASL syntax it's
"http://schemas.microsoft.com/mapi/proptag/0x36E5001E". If you want new
items created using your custom MessageClass you would set or create that
property to the custom MessageClass name string.
Any icon can be used (large and small) as long as they meet the requirements
for the form icons (16x16 for large icons and 32x32 for small ones).
"Tobias Böhm" <boehm.tobi@googlemail.com> wrote in message
news:8b3677cd-3474-4bc3-8d4b-e62e4d2820e1@18g2000yqa.googlegroups.com...
> Hello,
> I found
> Thanks,
> Tobi
F Auto changing email subject line in bulk Using Outlook 2
K Changing the Deleted Items location in Outlook 2019 Using Outlook 2
V Outlook 2021 Can anyone explain why my Outlook views keep changing?! Using Outlook 2
wayneame Changing the Form Used by Existing Task Items in a Folder Outlook VBA and Custom Forms 4
S Changing Message Class Outlook VBA and Custom Forms 4
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
Gary Hile Outlook 2016 changing editor options Using Outlook 6
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
Stephen Weinberg Changing the mailing address checkbox Using Outlook 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
A Outlook.com changing appointments Using Outlook 8
B Changing CC list to .add Outlook VBA and Custom Forms 2
Diane Poremsky Changing the Message Size in Exchange Server Using Outlook 0
Diane Poremsky Changing the default *.pst and *.ost sizes Using Outlook 0
P Message Class keeps changing back to IPM.Contact Outlook VBA and Custom Forms 2
L Office 365 Outlook changing default contact folder Using Outlook 0
Diane Poremsky Changing the From Domain in Office 365 Using Outlook 0
R The changing way to access information in Office 365 Using Outlook 0
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
divan VbaProject: Changing email format Using Outlook 15
C Changing Domain -- Assigned To User field Migration? BCM (Business Contact Manager) 1
M CHANGING ACCOUNT NAME Using Outlook 0
