VBA: Confused with variables between ThisOutlookSession and UserForm
XLinho
I like to move any sent e-mail according to three CommandButtons from a User Form.
I paste and copied the following code in ThisOutlookSession:
Public myCB As Byte
Public Sub Application_ItemSend(ByVal Item As Object, Cancel As Boolean)
'I admit I have no idea about the next lines with Dim and Set, just copied it from other forums...)
Dim myOlApp As Outlook.Application, _
myOlNS As Outlook.NameSpace, _
myDestNamespace As Outlook.NameSpace, _
myDestFolder As Outlook.MAPIFolder
Set myOlApp = Outlook.Application
Set myOlNS = myOlApp.GetNamespace("MAPI")
Set myMail = myOlApp.ActiveInspector.CurrentItem
ShowUFS:
UserFormSent.Show
Select Case myCB
Case 1
'Flag for Deletion and move to the subfolder "2B-deleted" in SentItems
Set myDestFolder = myOlNS.GetDefaultFolder(olFolderSentMail).Folders("2B-deleted")
Case 2
'Move to Standard SentItems
Case Else
'Pick any other folder
Set myDestFolder = myOlNS.PickFolder()
If myDestFolder Is Nothing Then
GoTo ShowUFS
Set myMail.SaveSentMessageFolder = myDestFolder
Obviously I have a UserFormSent with three CommandButtons and the following code in UserFormSent:
Sub CB_Delete_Click()
myCB = 1
UserFormSent.Hide
_______________
Sub CB_Pick_Click()
myCB = 3
UserFormSent.Hide
_______________
Sub CB_Sent_Click()
myCB = 2
UserFormSent.Hide
I thought with declaring myCB as Public, myCB would keep value 1, 2 or 3 when UserFormSent gets hidden, but it doesn't. Any solutions how to solve this (or use an entire different setup)? MessageBox just doesn't work for me...
O VBA Only works once then doesn't work Outlook VBA and Custom Forms 1
