Why is "Value Required" checkbox greyed out for Dates?
vincetaylor
Outlook 2016 64 bit
Does anyone know why the "A Value is required for this field" checkbox is always greyed out for OlkDateControl objects and DTPicker Objects.
And how can I make the checkbox active?
Adding a Validation formula like the one in the picture above doesn't work for me because it causes the form to be flagged as harmful.
S Displaying Date Value In Formula Outlook VBA and Custom Forms 6
M Outlook 2013 Replace Subject with Conversation (a "hidden" value). Outlook VBA and Custom Forms 0
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
M Copy "To" Address Value from a Newly Created Email to the "To" Address Field of Custom Form Using Outlook 4
J How to show the "value" of a user-defined Account field in a Contact Record BCM (Business Contact Manager) 2
D Custom Form - Show field-filled doc a or b based on value of field x Outlook VBA and Custom Forms 4
S Outlook code to validate textbox value Using Outlook 1
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
S Outlook custom checkbox not changing value Using Outlook 0
S Displaying the Remind Beforehand Value in Calendar List View Using Outlook 2
K TextBox on Custom Form Page :: Passing value from sender to the recipient Outlook VBA and Custom Forms 1
O Meeting Item SentOn Value Using Outlook 3
J Outlook 2010 Forms Help Needed "A field in this form requires a value." Using Outlook 6
C Custom Contact form - erase default value Using Outlook 0
F Change default value of date/time type from "None" to Blank Using Outlook 1
R Need code to gather value of custom field on addressentry.details dialog box Using Outlook 3
T You must Provide a value for this property on powershell cmdlet Exchange Server Administration 3
T To value Outlook VBA and Custom Forms 1
P Can you load an OlkComboBox and show a previously selected value? Outlook VBA and Custom Forms 1
X How to get the PR_ENTRYID value C# Outlook VBA and Custom Forms 3
S Re: Errormessage "A field requires a Value" Outlook VBA and Custom Forms 1
E Errormessage "A field requires a Value" Outlook VBA and Custom Forms 7
S Forms - unknown field requires a value Outlook VBA and Custom Forms 6
M Obtain property value by name Outlook VBA and Custom Forms 5
D Form - Specific "To" Recipient value Outlook VBA and Custom Forms 5
F Code to add items to list to deal with commas in value... Outlook VBA and Custom Forms 1
C How do I grab a field property (like .value) so I can modify it via OL code? Outlook VBA and Custom Forms 4
D Application.ActiveInspector().CurrentItem Returns Wrong(Old) Value Outlook VBA and Custom Forms 3
Q Load a recipient based on a value in a combo box Outlook VBA and Custom Forms 7
A Read Outlook Mail Item From Value Outlook VBA and Custom Forms 1
C date formulas / mathematics, setting a field one hour past another field value Outlook VBA and Custom Forms 1
A Populate task field based on value of other field Outlook VBA and Custom Forms 9
I IMAP - are emails dynamically fetched from server as required? Using Outlook 2
