How to set a flag to follow up using VBA - for addressee in TO field
Outlook 365 64 bit
i have embedded this macro :
Public Sub SetCustomFlag()
Dim objMsg As Object
Set objMsg = GetCurrentItem()
With objMsg
' due this week flag
.MarkAsTask olMarkThisWeek
' sets a specific due date
.TaskDueDate = Now + 3
.FlagRequest = "Call " & objMsg.SenderName
.ReminderSet = True
.ReminderTime = Now + 2
.Save
Set objMsg = Nothing
with some tweaks and seems to be working fine on outlook 2016 / o365 with exchange - thanks
the one thing I would love to have is to have this flag/reminder request sent, instead of all recipients to people in the TO field only.
(people in cc and bcc should not get the flag/reminder)
Is there a way to handle that?
appreciate any inputs
jf
hello Diane,
hope you are well and thanks for coming back!
the point of macroing this is to slipstream the admin of this flagging (1 click vs many).
I only need one type of flag with set parameters on reminder, and flag content and timing.
(task would be great too, but that does not work before sending.
is there a way to handle email separation (to and cc) and distribution with flag / no flag to these separate recipients?
thanks
justice
If you are setting a flag before sending, it will go to all recipients. To send a flagged message only to the To line would require you to send two messages - one to CC , one to To.
thanks for the input - i could not figure out how to implement your suggestion
I have realized however, that i can solve this in a different way.
i can have limited number of guys as recipients (they should get the flag anyway) and hardcode in this macro a forward to others
so i add this after the above with section:
With objMsg
Set myForward = objMsg.Forward
myForward.Recipients.Add "alias@domain.com; alias2@domain.com"
myForward.Send
there is only one problem with this: forward also forwards to the sender and that is not needed.
i was trying to use myForward.Recipients.Remove but could not figure a way to be able to run that.
is there a way to leave out the sender from this forward?
JF
Remove is not the way to do it.
Try myForward.to "alias@domain.com; alias2@domain.com" - this should replace the original sender
if that doesn't work (adding two or more names using to sometimes fails), use
myForward.Recipients.Add "alias2@domain.com"
many thanks for helping me!
i have changed the code to myForward.to but then it stops with "object does not support this method" (myforward.to "email")
this is the current code - which should run on a newly created message:
With objMsg
.TaskDueDate = Now + 2
.FlagRequest = "REVIEW THIS ITEM " & objMsg.Subject
.FlagDueBy = Now+2
.ReminderSet = True
.ReminderTime = Now + 1
.Save
'this part should forward the newly created message (all of its content) to the email address included. if this could be a local group, better
With objMsg
myForward.To "alias@domain.com"
myForward.Send
many thanks yet again
justice
With objMsg
.FlagDueBy = Now+2
.ReminderSet = True
.Save
With objMsg
myForward.Send
justice
Hello and happy new year!
I am just taking this up again, do you have by chance any suggestion how to move forward with this?
thanks a ton
justice
I'll take a look at it - I took a few weeks off at the end of December and just getting back to work. :)
I think the year end festive season is for fun, happy to hear that you've had some time off! :)
thinking about the problem - would it be better (easier) to create a new email with the contents of the flagged one, and send it to either hard coded recipients or better to local outlook address group?
thanks
justice
This is working for me -
Dim objRecip As Recipient
With objMsg
.FlagDueBy = Now + 2
.ReminderSet = True
.Save
With objMsg
Set objRecip = myForward.Recipients.Add("alias@domain.com")
    objRecip.Type = olTo
    myForward.Send
With objMsg
.ReminderSet = True
.Save
With objMsg
    myForward.Send
thanks for looking into this - really appreciate it!
This one certainly sends out a forward as well, which is a blitz for sure - but i encounter some problems:
- i prep a full mail, then press the button to invoke the above code/macro
- the macro sends a mail without the mail body, with the attachment, to both the original email recipient, and the coded one, w/o the flag and reminder
- then when pressing send on the original email, normal mail gets to the intended recipient with flag and body and attachment.
what i need to change is:
- mail recipient gets 2 mails - 1 from macro and 1 from normal send - but should get only one - the normal one after send (flagged etc)
- the macro recipient should receive a full mail - body and attachment (original mail recipient should not get this)
what should i change?
justice
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
efire9207 Set all properties Using Outlook 1
T How to set Default FONT for Email composing ? Using Outlook 0
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
Witzker Macro to set contact reminder to next day 9:00 Outlook VBA and Custom Forms 45
O Set columns for all (sub)folders Using Outlook 8
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
F Set (flagged) reminder for next business day Using Outlook 4
L how to set downloaded cached emails Using Outlook 5
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
A Block user to send emails to specific set of email ids Using Outlook 1
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
Diane Poremsky Exchange account set-up missing in Outlook 2016 Using Outlook 0
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
