How to delete a forum post?
ofw62
If, for a longer period of time, there are no replies on a forum thread, or, the solution has been found already, the post is of no use and should be deleted.
AFAIK users can not delete their post themselves. How to proceed then?
I have an addin that deletes posts with no answers - I think it is set for a year. I'll check and see if I can allow users to delete their own posts if no answers. (I don't want to let them deleted ones with answers - because there are some that will delete them as soon as they get an answer.)
Thanks a lot. I guess post -with- an a reply should not be deleted: the reply given my include a solution that may be of help for other users.
Those without a reply though, it makes sense that the user should be able to delete them.
Either he/she found solved the matter after posting, or there is no response for days, or the questions doesn't make sense as it is impossible to solve. In my case, I believe it is not possible to batch update the Message-field in Calendar (except then by opening each and every event, make the change and resave it).
Anyway, I'll try to delete the post.
Thanks again.!
Not sure it will work for post title "How to find and replace a word in Outlook-Agenda-Subject and Message?"
There is no 'Delete' option there, there is one below my post above.
May be you could delete it?
F Outlook 2021 Inbox delete icon missing Using Outlook 5
T Cannot delete a calendar Using Outlook 0
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
A Outlook 365 Delete entries in title field, address book Using Outlook 0
D Delete Outlook emails from MS server Using Outlook 17
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
G Automatically delete email when a condition is met Outlook VBA and Custom Forms 1
M Shift Delete doesn't delete email from server Using Outlook 3
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
P How did hacker cause link to delete and archive containing email? Using Outlook 6
J To delete the draft email Using Outlook 2
A Attachments.Delete Outlook VBA and Custom Forms 3
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
S How can I delete all copies of a given companies logo graphic from all my emails at once? Using Outlook 3
D after delete mail, open the next one Outlook VBA and Custom Forms 0
O Delete duplicate emails - subscription notifications Using Outlook 5
L Email Read and Delete Outlook VBA and Custom Forms 4
H Delete Calendar Entries in Using Outlook 2
D Delete Emails from Senders in Shared Mailbox Outlook VBA and Custom Forms 1
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
C Outlook 2016 cannot delete, email showing in root Exchange Server Administration 5
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
