Forward mails with "FW:" or "RE:" in title
Atch
Outlook 2019 64-bit
So after a bit of research I've come to the conclusion that Outlook has a sort of built-in protection that prevents automatically forwarding mails that come with a "FW:" or "RE:" in the title. Probably to prevent mail storms or something.
Is there a way to disable this security feature? I desperately need to forward emails like these.
Alternatively a VBA code to forward these mails could work, though what I've found here would need to be tweaked:
1. It doesn't forward attachments
2. It doesn't put a copy of the sent mail in the sent folder
3. It's not easily identifiable that the mail was actually forwarded. I've been using the Last Verb Exec Type & Time fields to format forwarded mails.
Hope someone can help me.
Others have reported that, but I don't forward enough to verify its true. A macro can forward them -but Outlook needs to be running 24/7 for it to work.
Forwarding shouldn't cause mailstorms (or they should be rare), because most forwarding is to another address you own.
You want the same behavior as when you hit the forward button?
The macro in the article you found would need one line changed and some removed
Sub SendNew(Item As Outlook.MailItem)
Dim objMsg As MailItem
Set objMsg = item.Forward
' do you need to update the subject ?
'objMsg.Subject = Item.Subject
objMsg.Recipients.Add "alias@domain.com"
objMsg.Send
Then there is this - needs the CC code removed - but this will do it.
A How to forward all e-mails from one address to five (5) other e-mail address? Using Outlook 1
K Reply or forward - some e-mails do not display correctly Using Outlook 3
H Forward E-mails at Certain Times in Outlook using VBA Outlook VBA and Custom Forms 1
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
