Outlook 2002- "Send" button has disappeared. Help please.
spin
Older version
The account will recieve emails just not send them.
I have:
- Deleted the email account and re-entered all of the details as using the settings from my email providers website. The "test" is succesful on all steps.
- Renamed "extend.dat" so it created a new file. This worked but seemed to have no impact on the send button vanishing.
- Played around with the taskbar settings to see if it was somehow hidden.
I am not sure what else to try. Any help would be much appreciated.
Can you send using Ctrl+S or Ctrl+Enter? Will it send if you set it to send immediately in options?
I'll need to boot up an old virtual machine to check - but as long as you have a working email account, the send button should be there. If there is no email account, then the send button is not shown (to the best of my recollection).
This is a pop account, correct? In account settings, select the email account - look at the change folder button at the bottom of the dialog - is it blank? If yes, click the button, select a different folder in a different data file and ok it - then go back in and choose the correct folder in the correct data file.
K Outlook 2002 Can Not Send Or Receive E-mails Using Outlook 3
S Transferring POP emails from Outlook 2002 to Outlook.com email in Outlook 2013 Using Outlook.com accounts in Outlook 8
D Syncing Outlook 2002 with iPad 128 KB Using Outlook 1
L Outlook 2002-2013 upgrade Using Outlook 3
A moving outlook 2002 from xp to win 7 or 8 Using Outlook 2
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
P How can I view a german email in outlook 2002? Outlook VBA and Custom Forms 1
D I need to know everything about Outlook 2002/XP Forms ! Outlook VBA and Custom Forms 1
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 5
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 23
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
