Error in FK_activitietable_activitytypestable
  • Thread starter Thread starter Dave C
Dave C
when I try and enter any contact updates I get a conflict with the FOREIGN
KEY constraint "FK_ActivitiesTable_ActivityTypesTable".The conflict cccurred
in atabase "......", table"dbo.ActivityTypesTable",column'ActivityTypeID'
IRIS;1002 Activities Table
The statement has been terminated....
Has anyone come across this before and if so how can I resolve
DC
On May 14, 3:14 am, Dave C <Da...> wrote:
> Hi
> Thanks
> DC
There are two tables in the database.
ActivitiesTable and ActivityTypesTable
Here I'm going to guess.
There's a column in ActivitiesTable that specifies the type of
activity and the value in that column must be a value in the
ActivityTypesTable. Somehow you have a record in ActivitiesTable with
a type not present in ActivityTypesTable.
If you know who to query SQL data, you could try finding that record
and updating its type column to a valid value. Or add the missing type
to ActivityTypesTable.
G Forms error on iCloud calendar Using Outlook 17
Sandgroper48 Automation Error Outlook VBA and Custom Forms 12
G Error - "Customized functionality in this application will not work because the certificate" Outlook VBA and Custom Forms 1
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
T Event Error on non existent Event. Using Outlook 2
A Links in email getting error message about group policy Using Outlook 4
Cathy Rhone Mail merge error message Using Outlook 1
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 4
