Is there no way to obtain sender's emailid from outlook calender d
V
viplav
I want to get the sender's emailId.
I am able to read all the data of calender by the below code but not the
sender's emailId.
====================CODE STARTS==================================
using Microsoft.Office.Interop.Outlook;
Microsoft.Office.Interop.Outlook.Application outlook = new Application();
Microsoft.Office.Interop.Outlook.NameSpace oNS = outlook.GetNamespace("MAPI");
oNS.Logon(Missing.Value, Missing.Value, true, true);
string currentUserEmail = oNS.CurrentUser.Address;
string currentUserName = oNS.CurrentUser.Name;
// Get the Calendar folder.
Microsoft.Office.Interop.Outlook.MAPIFolder objMAPIFolder =
oNS.GetDefaultFolder(OlDefaultFolders.olFolderCalendar);
//Get the Sent folder
MAPIFolder sentFolder =
oNS.GetDefaultFolder(Microsoft.Office.Interop.Outlook.OlDefaultFolders.olFolderSentMail);
Items sentMailItems = sentFolder.Items;
Items items = objMAPIFolder.Items;
foreach (object item in sentMailItems)
if (item is MailItem)
MailItem oneMail = item as MailItem;
string mailContent = oneMail.HTMLBody;
//item.sender is not available
foreach (object item in items)
if (item is Microsoft.Office.Interop.Outlook.AppointmentItem)
Microsoft.Office.Interop.Outlook.AppointmentItem mitem = item as
Microsoft.Office.Interop.Outlook.AppointmentItem;
string subject = mitem.Subject;
DateTime start = mitem.Start;
DateTime end = mitem.End;
string body = mitem.Body;
string location = mitem.Location;
string entryId = mitem.EntryID;
//sender email id not available
//string senderEmail = mitem.sender;
oNS.Logoff();
=================CODE ENDS=================================
But in any case whether reading appointments or sent folder emails, I am
unable to obtain the sender's email Id.
does anybody have any solution for this problem ?
K
Ken Slovak - [MVP - Outlook]
If you were to look at the Object Browser for those items you'd see that
Sender is not a valid property on the items. That's why that doesn't work.
Try using item.SenderEmailAddress or item.SenderName depending on what you
want.
That will work only for mail items since appointments don't have a sender.
You can use the Organizer property on an appointment.
"viplav" <viplav> wrote in message
news:CD45F1DE-C6AC-44C1-A900-1313ACC66FD8@microsoft.com...
> sender's emailId.
> oNS.Logoff();
V
viplav
Re: Is there no way to obtain sender's emailid from outlook calend
actually i am unable to find any property which can give me the sender's
email id. i have tried every existing properties and searched all the
accessible properties but without any result.
Sue Mosher [MVP]
What do you mean by "email id" -- the sender's name? Email address? Did you
follow Ken's suggestion of looking at the value of the SenderEmailAddress,
SenderName, and Organizer properties? What Outlook version are you coding
for?
Sue Mosher
news:8CD94D51-4223-4902-A173-E73C7AA26FFE@microsoft.com...
news:OkE724dEKHA.4704@TK2MSFTNGP04.phx.gbl...
> want.
> > sender's emailId.
> > oNS.Logoff();
V
viplav
by emailId I mean email address.
I have tried all the stuffs which includes ken's suggestion of trying out
"SenderEmailAddress", "SenderName" and anything else available.
But there seems to no way to get the email address of the sender.
--regards
K
So what do you get when you ask for SenderEmailAddress? That's the property
that returns the sender's email address (obviously), so what is it returning
to you?
news:32693BFD-5F17-49A1-8879-03C6964B98E0@microsoft.com...
> --regards
V
viplav
Nothing.
I am using Microsoft.Office.Interop.Outlook.dll on outlook 2007
the property "SenderEmailAddress" is simply not there. In the snippet that i
gave before(above) the object "mitem" should have given me
mitem.SenderEmailAddress form sender's email address.
Yesterday i tried "OUTLOOK REDEMPTON" from
here(http://www.dimastr.com/redemption/) and that gave me sender's email
address. "OUTLOOK REDEMPTON" provides a number of objects and functions to
work with properties and functionality not exposed through the Outlook object
model.
K
I'm very familiar with Redemption, and it does provide access to properties
not exposed in the Outlook object model, but that's not the case with
MailItem.SenderEmailAddress, which is exposed in the object model.
Open the Outlook VBA project and the Object Browser (Alt+F11, then F2).
Select the Outlook object model in the list of references and select
MailItem. Scroll down to the "s" area of the list and tell me you don't see
SenderEmailAddress. Do the same thing in the Object Browser in VS and that
property is also there. I don't know what interface you're looking at but if
it doesn't have that property it's not the correct interface.
news:8863CBCA-CE06-46F3-B093-AB918C228519@microsoft.com...
> Nothing.
> i
> object
> model.
A How to obtain the Distribution List of a Sender Outlook VBA and Custom Forms 4
F Obtain Members of a Distribution List Outlook 2003 c# Outlook VBA and Custom Forms 1
J Using Access to obtain E-mail address Outlook VBA and Custom Forms 5
L How I can obtain the text storage in a textbox in outlook? Outlook VBA and Custom Forms 1
M Obtain property value by name Outlook VBA and Custom Forms 5
D Outlook VBA forward the selected email to the original sender’s email ID (including the email used in TO, CC Field) from the email chain Outlook VBA and Custom Forms 3
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
J Outlook 2016 How tell Outlook not to trust sender? Using Outlook 1
M Screen Scrape Sender IP Address Outlook VBA and Custom Forms 6
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
D Moving Emails Based on Recipient/Sender Outlook VBA and Custom Forms 4
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
M Move new mail to folder based on sender address Outlook VBA and Custom Forms 2
D Inserting sender name and address with vba Outlook VBA and Custom Forms 1
M Blocked Sender List @Domain Not Working Using Outlook 0
B Can't expose sender email address when linking outlook to access Using Outlook 3
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender Using Outlook 0
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
O See recent emails from a sender Using Outlook 2
S announce email sender and subject when new email arrives... Using Outlook 7
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
P Mail delivery failed returning message to sender Using Outlook 1
K Outlook moves sender's mail, but there is no rule Using Outlook 0
Diane Poremsky Sort messages by Sender domain Using Outlook 1
B Find related messages to sender Outlook VBA and Custom Forms 7
B Find Related Emails to sender Using Outlook 1
