Opening a link from a specific sender automatically
Post number 4 has been selected as the best answer.
aniaaneczka
OS Version(s)
  1. Windows
Outlook 365 64 bit
Outlook version:     classic Outlook
I need to have a link from a specific sender open automatically in Firefox when the email is received.
This is the macro I am testing. It is probably a mess.
I get a Compile error with "unexpected identifier" pointing to the line Sub OpenLinksMessage().
Can anyone tell me how to get the macro work?
Private Declare PtrSafe Function ShellExecute _
Lib "shell32.dll" Alias "ShellExecuteA" ( _
ByVal hWnd As Long, _
ByVal Operation As String, _
ByVal Filename As String, _
Optional ByVal Parameters As String, _
Optional ByVal Directory As String, _
Optional ByVal WindowStyle As Long = vbMinimizedFocus _
) As Long
Dim Reg1 As RegExp
Dim M1 As MatchCollection
Dim M As Match
Dim strURL As String
Dim lSuccess As Long
Set olMail = Application.Firefox().Selection(1)
Set Reg1 = New RegExp
With Reg1
.Pattern = "(https?[:]//([0-9a-z=\?:/\.&-^!#$%;_])*)"
.Global = False
.IgnoreCase = True
if item.senderemailaddress = "someone@something.com" then
Set M1 = Reg1.Execute(olMail.Body)
For Each M In M1
strURL = M.SubMatches(0)
Debug.Print strURL
If InStr(strURL, "unsubscribe") Then GoTo NextURL
If Right(strURL, 1) = ">" Then strURL = Left(strURL, Len(strURL) - 1)
lSuccess = ShellExecute(0, "Open", strURL)
DoEvents
NextURL:
End if
Set Reg1 = Nothing
Hi Diane, I use 64 bit windows and outlook. Unfortunately, it only works in the Visual Basic editor, but not in my Outlook, where I created a rule: when a message with a specific text in the title arrives, the script should be executed. This is the VB script I'm using:
) As Long
Public Sub OpenLinksMessage()
Dim Reg1 As RegExp
Dim M As Match
Dim browserPath As String
browserPath = Chr(34) & "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" & Chr(34)
Set olMail = Application.ActiveExplorer().Selection(1)
With Reg1
' opens the first link. use false to open all
.Global = False
.IgnoreCase = True
If Reg1.Test(olMail.Body) Then
For Each M In M1
Shell ("C:\Program Files\Google\Chrome\Application\chrome.exe" & " -url " & strURL)
DoEvents
NextURL:
Set Reg1 = Nothing
That is not going to work in a rule -
needs to be something like Public Sub OpenLinksMessage(olMail as mailitem) - and the set olMail line removed.
these is an example here - there is one a bit under the first run a script macro for Run a script version for Chrome
Open Hyperlinks in an Outlook Email Message (slipstick.com)
A Opening a link from an email automatically Outlook VBA and Custom Forms 0
L Opening People Outlook 2021 Using Outlook 2
KurtLass Opening Graphics Attachments in Outlook 2021 Using Outlook 0
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 2
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
U Disable "Always ask before opening" Dialog Using Outlook 3
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Outlook 2010 Opening Mail Attachment Using Outlook 2
A Warning When Opening attachment Using Outlook 7
A Outlook 2016- unable to have all subfolders expanded when opening outlook Using Outlook 11
GregS Immediate crash on opening Using Outlook 3
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
J Opening Attachments - in People Using Outlook 2
Mistyfied Outlook 2016 not opening Using Outlook 2
M Update field codes when opening Outlook Template Outlook VBA and Custom Forms 2
R Outlook PST not opening Using Outlook 1
U .pst file error at opening outlook Using Outlook 1
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments Using Outlook 0
S macro for opening attachments and printing Using Outlook 1
Z how to make OL (2007) to use custom contact form when importing / opening .VCF? Using Outlook 1
T Opening email causes "Contacting ..." message Using Outlook 1
K Outlook 2013 stuck "processing" when opening. Using Outlook 3
S Opening Outlook Windows Using Outlook 1
S PoP up reminder while opening the outlook? Outlook VBA and Custom Forms 1
J Opening/Archiving/Import/Export PST files Using Outlook 4
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
E OL2007 on Exchange: opening OL on different computers Using Outlook 1
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
T Error opening mail with pictures - "The linked image cannot be displayed" Using Outlook 3
P I'm getting an error when opening Outlook "Mobile me stopped working Using Outlook 1
D opening Word Document in a business contact? BCM (Business Contact Manager) 3
B Contact changes from Personal to Shared when opening custom form Using Outlook 0
C How to stop iCloud calendars opening by default Using Outlook 8
U outlook 2010 freezes/crashes when opening encrypted e-mails Using Outlook 0
G OLMAPI32.dII error prevents Outlook 2010 from opening Using Outlook 2
D Custom Tool Bar and/or Commands do not remain when re-opening Outlook 2007 Using Outlook 3
G opening Outlook again after closing closing? Using Outlook 0
B Outlook 2010: how to mark messages without opening? Eg for deletion Using Outlook 2
M I cannot start Microsoft Outlook 2013 directly opening a .eml message Using Outlook 1
M Opening Word Doc's in Adobe Acrobat Pro Using Outlook 9
L Opening up Contact from an Email - Outlook 2007 Using Outlook 15
