Debugging from VS doesn't work anymore
  • Thread starter Thread starter escamoteur
E
escamoteur
I'm developing my first ad-in for Outlook 2007 using c#
I use a Shim created with the Shim-Wizzard and everything worked fine for a while. I could set breakpoints and debug without
problems.
Since this morning I can't debug anymore. When pressing "run" outlooks get started, but all my breakpoint have a sign saying "Module
not loaded"
When I check in the Trust Center->COM-Addin Dialog I see, that my add-in was not loaded and when I try to active it, nothing
happens.
Any idea???
Best
Tom
Please don't multipost. I see you solved the problem from a post in another
group.
"escamoteur" <mail@burkharts.net> wrote in message
news:6E1D9FFF-4C66-4EFF-823A-7B8B42A7AACE@microsoft.com...
> Hi,
> problems.
> not loaded"
> happens.
> Any idea???
> Best
> Tom
Sorry, I didn't want to upset anybody. But 'm still confused which is the best newsgroup?
microsoft.public.outlook.program_addins or microsoft.public.developer.outlook.addins ?
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:uncQGjFEKHA.4608@TK2MSFTNGP02.phx.gbl...
> group.
> > Hi,
> > problems.
> > not loaded"
> > happens.
>> Any idea???
>> Best
> > Tom
Either are OK. If you add both to a post that's OK too. Then anyone who
looks at the post in one group and marks it read won't see it again in the
other group. If you make separate posts to both groups that won't happen.
news:568EB2D9-CBF4-412F-BDA6-F59BAFB8732E@microsoft.com...
> best newsgroup?
> Best
> Tom
Ok thanks, will do it in future
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:OKVAT3HFKHA.4608@TK2MSFTNGP02.phx.gbl...
> > best newsgroup?
>> Best
> > Tom
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
M Shift Delete doesn't delete email from server Using Outlook 3
C Outlook doesn't feel reliable, anymore Using Outlook 5
C View doesn't refresh (fields or formatting) Using Outlook 1
J search doesn't find anything Using Outlook 1
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
GregS Simple calendar sharing doesn't work Using Outlook 6
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Junk mail doesn't work Using Outlook 3
Laurent Duchastel New email setup dialog doesn't allow alias Using Outlook 2
C scanpst.exe doesn't repair .pst file Using Outlook 1
Caio "From" field doesn't show extra email addresses in Outlook 2016. Using Outlook.com accounts in Outlook 6
O Worksheet doesn't show on jumplist Using Outlook 1
C Outlook 2016 doesn't show contacts in address book Using Outlook 2
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
S Outlook 2013 doesn't download html messages Using Outlook 0
M Google Apps Mail *SENT* from iPhone doesn't download to Outlook via POP3 Using Outlook 1
M Marco doesn't show up when using Alt-F8 Outlook VBA and Custom Forms 2
P AutoForward Randomly Doesn't fwd emails Using Outlook 3
Diane Poremsky Receive a Reminder When a Message Doesn't Arrive? Using Outlook 10
K Macro doesn't recognize local mails from colleagues Outlook VBA and Custom Forms 2
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
M Outlook hidden even when open (maximising doesn't fix it) Using Outlook 2
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
M Address book doesn't update contacts? Please any help would be great! Exchange Server Administration 4
A yahoo mail doesn't send or receive reliably Using Outlook 1
S VBA to modify appointment item in additional Exchange account doesn't work Using Outlook 0
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
T doesn't show up previous info (email, contacts and tasks)after windows up date Using Outlook 0
O Change folder doesn't work Using Outlook 2
G run-time 438: object doesn't support this property or method Using Outlook 2
