ComboBox with Multi columns
  • Thread starter Thread starter DBH
DBH
I have a combo box in my Custom Outlook form that has three columns in the
combo box. This data is retrieved via an Access database
when I look at the Value property of the combo box, I can only see one of
the columns ( I believe its the bound column in the combo box.
How can I access the other values in the selected line of the combo box?
( I need to place the addtional info in other parts of my form, typically a
text box)
Dave H
Use the ComboBox.Column method for that. See
http://msdn.microsoft.com/en-us/library/bb207615.aspx
Sue Mosher
"DBH" <dbh@siscom.net> wrote in message
news:%23rlK7YWMKHA.4124@TK2MSFTNGP04.phx.gbl...
> a text box)
> Thanks!
> Dave H
Tried cboGroupCategory.Columns(1).Value and a couple variations and Outlook
says its it doesn't support this property or method.
Am I missing something?
Dave
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in message
news:%23Umk$fWMKHA.1372@TK2MSFTNGP02.phx.gbl...
> > Sue Mosher
> > a text box)
> > Thanks!
> > Dave H
Yes, you apparently missed the fact that the method name is Column, not
Columns.
Sue Mosher
news:eXfMBuWMKHA.5460@TK2MSFTNGP02.phx.gbl...
> Outlook says its it doesn't support this property or method.
> Thanks!
> Dave
> >>the combo box. This data is retrieved via an Access database
> >> of the columns ( I believe its the bound column in the combo box.
> >> typically a text box)
Eyesite.... A wonderful thing to have!!!!
Thanks and it worked great!!!
Regards and many thanks!!!
Dave
news:ehBbiFXMKHA.4572@TK2MSFTNGP02.phx.gbl...
> Columns.
> > Sue Mosher
> > Thanks!
> > Dave
> >>> box? ( I need to place the addtional info in other parts of my form,
K Incorporate selection from combobox into body of email Outlook VBA and Custom Forms 0
T Outlook Template - textbox visible based on combobox selection Using Outlook 1
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
C Autofill subject line in appointment from options selected in combobox Using Outlook 6
B Contact Page 2 Combobox via Registry Outlook VBA and Custom Forms 6
N Combobox in outlook add ons toolbar not firing event on main window resized Using Outlook 3
J userform combobox Outlook VBA and Custom Forms 1
R combobox list in userform Outlook VBA and Custom Forms 1
K Alignment in Combobox Outlook VBA and Custom Forms 1
P Setting combobox properties from Outlook 2007 Add-in Outlook VBA and Custom Forms 9
K Adding watermark to Combobox in Outlook. Outlook VBA and Custom Forms 1
C ComboBox data Outlook VBA and Custom Forms 2
S ComboBox (using Commas) Outlook VBA and Custom Forms 4
S Default Selection For Multi-Select List Box Outlook VBA and Custom Forms 1
A Multi-select Listbox Outlook VBA and Custom Forms 6
L Unintentionally closing Outlook w multi monitors Using Outlook 3
Mark Foley Outlook multi-spacing Thunderbird signatures when replying Using Outlook 0
O How to display multi-line task in To-Do List - Outlook 2010 Using Outlook 1
K Outlook 2013 Multi Accounts set Default different calendar Sender Using Outlook 2
B Multi Room (10) Calandar Using Outlook 1
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
R Can BCM use Public Folders and Exchange for multi-user/ BCM (Business Contact Manager) 1
A Daily hours of recurring/ multi-day appts, & accessing mult calend Outlook VBA and Custom Forms 2
C Configuring Inbox columns Using Outlook 2
E Custom formula for columns Using Outlook 3
O Set columns for all (sub)folders Using Outlook 8
C Columns in relationship list BCM (Business Contact Manager) 1
W Outlook Columns "First Name" & "Last Name" Using Outlook 2
C Outlook 2007 Select Names Default columns Using Outlook 3
R How to modify Outlook Select Rooms form columns Using Outlook 1
C Outlook 2007 - Recover Deleted Items - Columns to Choose from Using Outlook 1
S Change Columns of Linked Accounts and Business Contacts BCM (Business Contact Manager) 1
C Change the related contect diplay columns BCM (Business Contact Manager) 4
williamlambton Customised To, CC, BCC and Have-replies-sent-to columns in message lists. Using Outlook 16
T User Defined Fields_Difference between columns BCM (Business Contact Manager) 4
