Setting combobox properties from Outlook 2007 Add-in
P
paresh
Could any one please help me with setting below properties for combobox
created on Outlook toolbar using Outlook 2007 Add-in. Please refer attached
initial code I wrote to create combobox in my Outlook command bar.
Could you tell me how to achieve below items:
1. When I select any "test" items from combobox the myComboBox_Click()
doesn't get called. Could you tell me what is wrong in the code?
2. How to add "FaceID" along with msoComboLabel properties? Basically I
want to have picture with the label name. I cannot use ".FaceID" as it gives
compile time error "method or data type not found". Could you help me on this.
Any help would be much appreciated.
My code:
' I have written below code in Connect.Dsr
' For your information, the similar methods work for CommandBarButton
Private WithEvents myComboBox As Office.CommandBarComboBox
Private Sub myComboBox_Click()
MsgBox "Combobox selection change event"
Set mylComboBox = myCommandBar.Controls.Add(msoControlComboBox)
With myComboBox
> OnAction = "myComboBox_Click"
> Style = msoComboLabel
> AddItem "test1"
> AddItem "test2"
> AddItem "test3"
> Visible = True
K
Ken Slovak - [MVP - Outlook]
If you are going to write Outlook and Office addins you really need to
become familiar with the object models you are working with. Try looking in
the Object Browser sometime.
There is no Click() event for a CommandBarComboBox control, and no support
for images. You can only do what the controls you are working with support.
"paresh" <paresh> wrote in message
news:2019CD69-6D15-4CF5-A9A5-68D8D521AF8D@microsoft.com...
> Hi,
> attached
> gives
> this.
> My code:
> End Sub
> With myComboBox
> .OnAction = "myComboBox_Click"
> .Style = msoComboLabel
> .AddItem "test1"
> .AddItem "test2"
> .AddItem "test3"
> .Visible = True
> End With
> End If
> Thanks.
P
paresh
Thanks a lot Ken. That was the precise answer. I looked into Object browser
and then only I have posted this question but now I realized that I looked in
VB Combobox and not CommandBarComboBox.
I am curious then is there any way to create VB combobox on Outlook toolbar?
I want to handle click event and need some small gif images inside that.
If it is possible in any aspects, I would be fine.
Thanks for being there.
Paresh
> > Hi,
> > attached
> > gives
> > this.
> > My code:
> > End Sub
> > With myComboBox
> > .AddItem "test1"
> > .AddItem "test2"
> > .AddItem "test3"
> > .Visible = True
> > End With
> > End If
> > Thanks.
P
paresh
The other thing is below method doesn't work either. It gives compile time
error "The procedure declaration doesnt match description of event or
prcedure having the same name". Could you please tell me what is wrong here?
Sub myCombobox_Change(Ctrl As Office.CommandBarComboBox)
MsgBox "Combobox selection changed"
> > Hi,
> > attached
> > gives
> > this.
> > My code:
> > End Sub
> > With myComboBox
> > .AddItem "test1"
> > .AddItem "test2"
> > .AddItem "test3"
> > .Visible = True
> > End With
> > End If
> > Thanks.
K
Normally that's not possible. Add-In Express lets you use controls that are
managed code controls such as a combo, but only if you use their framework.
They are using Win32 API hacks to put things where they want them and then
using message hooks to listen for events on those controls. Otherwise you
just have to use what you are given.
news:A57483DE-4307-4E72-BF20-918AB6BD154E@microsoft.com...
> browser
> in
> toolbar?
> Paresh
K
The event handler signature looks OK, but that should be automatic in VB6 if
you declared myCombobox WithEvents.
news:85280AB1-6B24-4927-90D2-41D11DB3A8E4@microsoft.com...
> here?
> End Sub
> Thanks.
P
paresh
Ken, please refer my complete code given below. It gives the same error.
Sub myComboBox_Change(Ctrl As Office.CommandBarComboBox)
Set myComboBox myCommandBar.Controls.Add(msoControlComboBox)
With myComboBox
> BeginGroup = True
> Caption = "Test"
> Enabled = True
> OnAction = "myComboBox_Change"
> AddItem "Test1"
> AddItem "Test2"
> AddItem "Test3"
> Visible = True
When I change myComboBox_Change event to just Change event, it doesnt give
that error but doesn't work either. When I select the "Test1" from combobox,
it doest print my message box.
Sub Change(Ctrl As Office.CommandBarComboBox)
Could you please tell me what could be wrong here?
Thanks, Paresh
> > here?
> > End Sub
> > Thanks.
P
paresh
The below worked.
Private Sub myComboBox_Change(ByVal Ctrl As Office.CommandBarComboBox)
Please note the ByVal word.
> End Sub
> With myComboBox
> .BeginGroup = True
> .Caption = "Test"
> .Enabled = True
> .OnAction = "myComboBox_Change"
> .AddItem "Test1"
> .AddItem "Test2"
> .AddItem "Test3"
> .Visible = True
> End With
> End Sub
> Thanks, Paresh
> > > here?
> > > End Sub
> > > > Thanks.
K
In VBA/VB the default is ByRef, I guess it didn't like that implicit ByRef
and wanted a ByVal. Good detective work.
I haven't used that control very often in toolbars, it's just too funky in
how it works for my taste.
news:EDB279D8-EEBE-4960-8CBD-941945D23DA2@microsoft.com...
> The below worked.
> Thanks.
P
paresh
Yes Ken, you are correct. I have wasted two days in that simple "ByVal" Word :)
Thanks, Paresh
> > The below worked.
> > Thanks.
AlphonseG Outlook 365 Outlook Crashes on setting SaveSentMessageFolder Outlook VBA and Custom Forms 5
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Setting rules Using Outlook 1
B Setting defaults Using Outlook 2
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
Jennifer Murphy Equations don't comply with style setting to left justify Using Outlook 0
J Setting default address book Using Outlook 0
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
Diane Poremsky Setting up an Outlook.com IMAP account Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts Using Outlook 0
Diane Poremsky Adjusting Outlook's Zoom setting in Email Using Outlook 0
O Setting default format for composing/replying to emails Using Outlook 3
B Outlook Calendar/setting appointments Using Outlook 1
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
L Setting up my PA's Outlook Using Outlook 7
N "Instant Search" setting a default view Using Outlook 3
H SETTING UP A "NEW" NEVER HAD NEVER USED EMAIL ACCOUNT Using Outlook 9
K Setting Default Email Address for Meeting Replies Using Outlook 3
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
D Setting defult "Show a room list" Using Outlook 0
Horsepower Setting appointments in calendar Using Outlook 3
J Setting tabs in contacts / notes field Using Outlook 0
T Setting a Default Subject from a certain Signature Using Outlook 0
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
mikecox setting Default area code in Contacts Using Outlook 5
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
V View zoom setting changing Using Outlook 1
C Setting up Outlook 10 on Widows 8 using Google Server Using Outlook 3
I Outlook Appointments - Setting default text in message body Using Outlook 3
T Setting Color codes for each user of a shared Calendar Using Outlook 1
J setting date in drafts Using Outlook 4
