"Outlok like" control - users(contacts) resolving
j
Hi ALL,
I'm using VSTO 2005, C# 2.0 WinForms, Redemption for Otulook.
I have winForm - mail message ( looks like Outlook' inspector ),
which concists TO field, CC filed, Subject field and Body field.
I need to develop control ( the TO field ) that will behave like an
Outlook's TO field.
For resolving user i use the Redemption.dll.
Any ideas how can i implemetn in a good way such issue? or maybe such
control exists.
Thanks in advance.
K
Ken Slovak - [MVP - Outlook]
If you want an address book dialog displayed you can use
RDOSession.AddressBook.ShowAddressBook().
You don't mention the Outlook version you're developing for, which you
should always do, but if you are developing for Outlook 2007 you can use
NameSpace.GetSelectNamesDialog() to display the address book dialog.
"j" <evgeny.br@gmail.com> wrote in message
news:22c4bbab-52c9-4420-8f06-c5dd57d10823@a6g2000vbp.googlegroups.com...
> Hi ALL,
> Outlook's TO field.
> control exists.
> Thanks in advance.
j
On Oct 8, 3:45 pm, " - " <kenslo...@mvps.org
> http://www.slovaktech.com
> "j" <evgeny...@gmail.com> wrote in message
> > Hi ALL,
> > Outlook's TO field.
> > control exists.
> > Thanks in advance.
sorry, i use outlook 2003.
Also i use RDOSession.AddressBook.ShowAddressBook(), however
after user selected users (contacts) from addressBook i should place
them in the
textbox control with useres namaes separated with comma and
underline.
What is your suggestions??
Thanks in advance
K
What textbox control? Your textbox for To?
You get back a collection of RDORecipients from that dialog. You can get
whatever properties you want from each RDORecipient object, such as Name,
Address, AddressEntry.SMTPAddress and so on. You can then format things any
way you want, including with underlines.
news:5658ac18-1f19-473f-bf1f-d8c257734ba4@b18g2000vbl.googlegroups.com...
<snip
them in the
underline.
Thanks in advance
j
On Oct 8, 8:50 pm, " - " <kenslo...@mvps.org
> <snip
> Thanks,
> them in the
> underline.
> Thanks in advance
i want to implement control (like in Outlook, when i open new
Insepctor),
with autoComplete, and underlining.
if such control exists, free or commercial.
Any ideas?
K
I've never seen a control like that, but I haven't looked. That's something
you can Google for if you're interested. Or you can simulate that yourself,
it's not hard to underline text in a textbox control and to handle events in
it.
news:a3a70e95-b3db-4b7e-a5e2-ef7a246e394f@c3g2000yqd.googlegroups.com...
<snip
Insepctor),
Any ideas?
j
On Oct 12, 3:24 pm, "
> it's not hard to underline text in a textbox control and to handle eventsin
> it.
> <snip
> Thanks,
> Insepctor),
> Any ideas?
Thanks Ken,
Thanks for advices, after some research i found that i can use/add
formatting in WinForm's textbox
it's only plain text.
so ......
The good thing that WinForm's texBox control has built-in autocomplete
(it's like in Outlook's inspector To,CC,BCC fields).
However without formatting.
Any ideas?
Thanks in advance.
K
Ideas on what? Text formatting? You can set the font in a textbox, which
includes setting things like underlining. You can also use a rich text
textbox. You'd have to play with the formatting yourself to get the effect
you want.
news:a3bdbd8d-0fc7-4bfd-a5c1-6e92a0ee8356@g19g2000yqo.googlegroups.com...
<snip
Thanks Ken,
so ......
Any ideas?
Thanks in advance.
j
On Oct 13, 3:42 pm, "
> you want.
> <snip
> Thanks Ken,
> so ......
> Any ideas?
> Thanks in advance.
i can add the underline formatting, but what about autocomplete? i
want to achieve Outlook's look and feel.
also in case i add underline fomratting on TextBox, i'll see
continiously underline ( include spaces).
what can u suggest?
Thanks in Advance Ken.
K
If autocomplete or autosuggest is what you want in a textbox you have to
implement that yourself. As each Change event fires for the control you
would take the text as it is then and do a search in contacts folders and
aggregate those that match the text you have. You'd have to present them in
some sort of dialog or popup and then repeat for each new character entered.
If you want an underline format to apply on to parts of the text I don't
think you can do that in a normal textbox. You might be able to in a rich
text textbox, I'm not sure since I almost never use those. Or you'd have to
hunt around for a control that meets your requirements from some 3rd party
vendor.
news:c0422c92-2cf3-4a20-8a64-3d84725f1d56@p25g2000yqh.googlegroups.com...
<snip
what can u suggest?
j
On Oct 19, 3:42 pm, "
> vendor.
> <snip
> Thanks,
> what can u suggest?
Thanks Ken,
Maybe you fmiliar with some 3rd party control that represent the TO,
CC, BCC field in Outlook?
Thannk you in advance.
K
No, I'm not familiar with controls like that (but I've never looked for
them).
news:bb4c1221-2b13-4eb4-b89a-d26d0340fd5f@k26g2000vbp.googlegroups.com...
<snip
Thanks Ken,
T outlok.com using MS Outlook Using Outlook 6
S Outlok 2007 add-in PJ Correspondence Log-How do I get it loaded? Using Outlook 7
glnz O365 - How to control whether my From name shows as "Dicky". Using Outlook 2
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
D font control by keyboard Using Outlook 2
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
J Control Panel Mail (settings) icon missing Using Outlook 2
B outlook view control Outlook VBA and Custom Forms 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
Ascar_CT MS Outlook 2010 with Hotmail connector went spam control nuts Using Outlook.com accounts in Outlook 1
N Control ID for Outlook 2013 “Recover Deleted Items From Server” Using Outlook 0
Richer Fortin Control parameters in Social connectors Using Outlook 1
A Out of control Using Outlook 1
P Outlook 2010 custom form olk control font size increases everytime form is published Outlook VBA and Custom Forms 1
V iCloud Control Panel v3.x Released Using Outlook 2
L Contact Form - Recipient Control Field Using Outlook 2
M Custom Contact form queries (date control & contact/calender linking) Using Outlook 1
D iCLoud Control Panel 2.1 Using Outlook 3
D iCloud Control Panel -- 1 vs 2 Using Outlook 1
B Font for Tab Page in Mutipage Control Using Outlook 1
D Mail in Control Panel Won't Launch Exchange Server Administration 5
W inserting activeX/user control into form Outlook VBA and Custom Forms 1
D Outlook 2010 sets own User-Agent in webbrowser control traffic Outlook VBA and Custom Forms 1
J Using Group Policy to control Outlook security/attachments behaviour Outlook VBA and Custom Forms 1
T Ribbon Control questions Outlook VBA and Custom Forms 7
A Contact form looks quite different after adding a new control? Outlook VBA and Custom Forms 1
A Help creating custom Contacts form - what type is 'Email' control? Outlook VBA and Custom Forms 1
H Drag and Drop Outlook mails into a Windows Form Control with eml extension Outlook VBA and Custom Forms 1
H Accessing a control on a frame in Outlook with VBScript Outlook VBA and Custom Forms 1
E Currency Edit Control on custom Taskpanes Outlook VBA and Custom Forms 1
S Custom Task Form - Reminder Control Outlook VBA and Custom Forms 1
J Outlook View Control SaveAs Outlook VBA and Custom Forms 1
E recipient control or suggest name Outlook VBA and Custom Forms 1
N Disable control CTRL button when dragging items/folders - Outlook Outlook VBA and Custom Forms 2
S A problem using outlook RichEdit control Outlook VBA and Custom Forms 2
J Microsoft SQL control within custom form Outlook VBA and Custom Forms 1
N Load audio file into Media Player control Outlook VBA and Custom Forms 2
V Latest Changes to form not appearing for some users Outlook VBA and Custom Forms 3
T How to configure Outlook for two users on a single Windows account Using Outlook 3
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
V Form data not sending for some users Outlook VBA and Custom Forms 2
G Updating VbaProject.OTM on several users Outlook VBA and Custom Forms 3
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
V extract users of a particular department Outlook VBA and Custom Forms 1
Z Tasks from some users show up as emails Using Outlook 4
