Separate string in email body
  • Thread starter Thread starter navin
N
navin
Hello Everyone,
For one of my applications, I insert the details of the mail into a
database (Sender Name, Date received etc..) which is working fine.
Hoever, In the middle of body of the mail, i have a string separated
by commas and I need to split this string.
Please let me know if this possible.
Navin
Sure it's possible.
How would depend on what language you're using, and how you propose to
recognize that string.
It also would help to know if you are using the Body or HTMLBody property.
Stating the Outlook version would earn you bonus points.
"navin" <navin.narayana@gmail.com> wrote in message
news:122358e5-ee56-4fe6-af6d-74b388b9c04a@o10g2000yqa.googlegroups.com...
> Hello Everyone,
> Thanks,
> Navin
Thanks for replying to my questions.
Mail format is HTMLBody and I am using Outlook 2003. Below is the mail
which i receive.
Dear Navin,
This is to notify you that you have received a new work item from Work
Manager system.
Please follow the link below to review the work item.
WorkItem, Profiler Approval for Amendment 1, Corp.Services_408_Sun
Micro__StartDate__A1 <---- This is a link which takes me to the order
when clicked.
I need to split the above string which is separated by comma.
Thanks again for your help...
Navin
On Oct 13, 1:37 am, "
<kenslo...@mvps.org> wrote:
> Sure it's possible.
> It also would help to know if you are using the Body or HTMLBody property..
> http://www.slovaktech.com
> "navin" <navin.naray...@gmail.com> wrote in message
> > Hello Everyone,
> > Thanks,
> > Navin-
Since you didn't bother to say what language you plan to use I'd have to
guess and say if you are using VBA/VB6 you'd use the Split() function which
returns an array of items split by a supplied delimiter. If you are using a
managed code language you'd use the .Split() function there on the string.
Use the Help on Split() for whatever language you're using to get the exact
syntax.
You'd find the string I guess by looking for "WorkItem" I guess, if that's
consistent. Then you would in the case of HTML look for a <br> or <p> or
whatever is used to end that text.
news:e6b6711b-b4f7-417c-a235-d86b12e53e22@a7g2000yqo.googlegroups.com...
which i receive.
Dear Navin,
Manager system.
when clicked.
Navin
M Separate Internal and external emails in outlook Using Outlook 1
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
M setting up 2 separate businesses in Outlook 2010 Using Outlook 2
P [SOLVED] How to separate/show appts by users on one sheet Using Outlook 2
N separate signatures for different accounts Outlook VBA and Custom Forms 6
P Does Bus. Cont. Mgr run separate from personal database? BCM (Business Contact Manager) 1
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
Z WebView doesnt function with separate pst Outlook VBA and Custom Forms 3
Beeto Replace a string in body Outlook VBA and Custom Forms 2
skyfox VBA to search email subject field for a certain string Outlook VBA and Custom Forms 3
C Save Subject of Received Email as a String Outlook VBA and Custom Forms 1
P String manipulation in Outlook VBA Outlook VBA and Custom Forms 2
M Find a String in Email Attachment(s) Outlook VBA and Custom Forms 1
S [O2007] -> How to search for a string in the body and get the line number? Outlook VBA and Custom Forms 1
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
P SPAM message about Comcast email migration to Yahoo Using Outlook 1
P anything new on the supposed shutdown of comcast.net email? Using Outlook 6
W frustrating trying to change email password Using Outlook 5
R File not found when sending email with attached pdf file Using Outlook 2
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
P Xfinity/Comcast email service stopping sometime in 2025 - warning Using Outlook 5
O Two identical email accounts in Offline Global Address List Using Outlook 2
H Spam email in Gmail not visible in Outlook Using Outlook 3
L Hide Selected Email Address from Address Book Using Outlook 5
Y QQ on Scheduled Delivery of an Email Using Outlook 0
T Replace Text in Email Subject Outlook VBA and Custom Forms 3
Rupert Dragwater Cannot reestablish gmail (email address) account in Outlook 365 Using Outlook 11
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
M Thunderbird email client - I wonder Using Outlook 1
D Outlook Desktop App Email Software Using Outlook 0
T Outlook 2010 Creating a email 'Group' in OL 2010 Using Outlook 2
