setting up 2 separate businesses in Outlook 2010
mdhreno
I have been searching the web for a few hours and searched this site. I am simply trying to create two completely separate businesses in Outlook 2010, 32 bit with different emails, calenders, task lists etc. I don't want them to share the same data or anything like that. How do I accomplish this? I know this must be simple but I cannot figure it out. Please help a fella out. Thank you!
You have two options - you can make two profiles, one for each acccount or you can add both accounts to one profile and use the default setup of 1 pst per account. Outlook 2010 will reply using the account whose folders you are viewing. If you add two accounts in one profile its a little easier because you don't need to close and reopen outlook.
To make two profiles go to Control panel and search for Mail - make one profile for each account and set outlook to ask which profile when you start it.
mdhreno
Thank you Diane, I tried to follow your advise but was having a hard time finding the Control Panel. I finally did a search for that and found this site- http://support.risualblogs.com/blog/2012/01/16/outlook-2010-mail-control-panel-location/. Basically I ended up cutting and pasting the location he provided in my run box and finally got to the Control Panel.
The following is the relevant information from that site I linked above-
Here is the location of the mail control panel just in case you cannot see it in the list of control panels that are available:
C:\Program Files\Microsoft Office\Office14\MLCFG32.CPL
OR
C:\Program Files (x86)\Microsoft Office\Office14\MLCFG32.CPL
You can simply copy and paste the lines above into a run box to display the mail setup control panel:
After I did that, everything was easy to do. Thank you so much! I don't know why I couldn't find the Control Panel in Outlook when I had it open. I still haven't found it from Outlook. Only when I did the search in my run box.
Anyhow, I got it set up the way I wanted and I appreciate your help.
AlphonseG Outlook 365 Outlook Crashes on setting SaveSentMessageFolder Outlook VBA and Custom Forms 5
Marc2019 Setting up an Outlook Account on Mac Os 10.6.8 Outlook 2011 Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
B Setting rules Using Outlook 1
B Setting defaults Using Outlook 2
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
Jennifer Murphy Equations don't comply with style setting to left justify Using Outlook 0
J Setting default address book Using Outlook 0
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
Diane Poremsky Setting up an Outlook.com IMAP account Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts Using Outlook 0
Diane Poremsky Adjusting Outlook's Zoom setting in Email Using Outlook 0
O Setting default format for composing/replying to emails Using Outlook 3
B Outlook Calendar/setting appointments Using Outlook 1
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
A Can't stop Outlook.com from setting reminders on appointments? Using Outlook.com accounts in Outlook 3
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
L Setting up my PA's Outlook Using Outlook 7
N "Instant Search" setting a default view Using Outlook 3
H SETTING UP A "NEW" NEVER HAD NEVER USED EMAIL ACCOUNT Using Outlook 9
K Setting Default Email Address for Meeting Replies Using Outlook 3
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
D Setting defult "Show a room list" Using Outlook 0
Horsepower Setting appointments in calendar Using Outlook 3
J Setting tabs in contacts / notes field Using Outlook 0
T Setting a Default Subject from a certain Signature Using Outlook 0
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
mikecox setting Default area code in Contacts Using Outlook 5
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
D How do I start completely from scratch in setting up Outlook 2013? Using Outlook 6
V View zoom setting changing Using Outlook 1
C Setting up Outlook 10 on Widows 8 using Google Server Using Outlook 3
I Outlook Appointments - Setting default text in message body Using Outlook 3
T Setting Color codes for each user of a shared Calendar Using Outlook 1
J setting date in drafts Using Outlook 4
