How to read color of form region title?
Mark B
I want my combobox text to be the same color as the form region title.
How can I programmatically read that color?
And other Outlook screen item colors for that matter?
TIA
K
Ken Slovak - [MVP - Outlook]
As far as I know the only way to do that is to get the screen coordinates of
a point and read the pixel at that point using API calls. There might be
something also in the CLR to read screen pixels, I'm guessing there is but I
haven't tried that so I can't be positive.
"Mark B" <none123@none.com> wrote in message
news:OsOZBX5SKHA.4028@TK2MSFTNGP05.phx.gbl...
> TIA
T E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
J From column changes when message is read Using Outlook 1
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
S Duplicate Read Receipt Using Outlook 4
K Read, unread, i'm losing clients! Using Outlook 1
