how do I work with oft files in outlook 2007
  • Thread starter Thread starter Patrick
P
Patrick
I outlook 2003 I used to work with a personal toolbar which contained some
buttoms pointing to oft files.
Now, with outlook 2007, I always get the message
Microsoft Office has identified a potential security concern.
This location may be unsafe
<the path and name of the oft file
Hyperlinks can be harmful to your computer and data. To protect your computer,
click only those hyperlinks from trusted sources.
Do you want to continue ?
HOW CAN I AVOID THIS ENOYING MESSAGE ?
If the .oft files just have boilerplate text and no form design, you should
be able to put them (or shortcuts to them) on your Desktop or in any other
convenient folder and launch by double-clicking. Another option is to write
a little VBA macro to launch each with the
Application.CreateItemWithTemplate method.
Sue Mosher
"Patrick" <Patrick> wrote in message
news:8C1C94EA-F94E-40D6-9532-B92E40F42821@microsoft.com...
> computer,
J Outlook .oft files Using Outlook 5
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
W Broken Folder Loop - Outlook 2007 (.oft files) Using Outlook 2
P outlook 2007 - custom buttoms with hyperlinks to oft files Outlook VBA and Custom Forms 1
M Why oft-file opens as outbox not as draft Outlook VBA and Custom Forms 4
D forward email with attachment using .oft Using Outlook 3
airtas oft templates not sending changes Using Outlook 2
L OFT file problem Using Outlook 5
H URL's don't work in .oft file Using Outlook 1
C Custom .oft / Printing Issue(s) Using Outlook 1
V New problem, .oft extentions in Outlook 2013 Using Outlook 5
F CAN'T SAVE OUTLOOK 2010 E-MAIL TEMPLATE (.oft) Using Outlook 1
2 Create an email brochure - oft file? Using Outlook 3
N How to automatically update all fields in an Outlook message template (OFT)? Using Outlook 9
R Outlook Rules and OFT templates Outlook VBA and Custom Forms 1
J How do I send a completed .oft form? Outlook VBA and Custom Forms 4
S Thank you Diane, Plus pst files question Using Outlook 8
M Get metadata from .msg files saved to local drive Outlook VBA and Custom Forms 26
U Trouble sending large files to a email group but can to the individuals in that group Using Outlook 8
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
S Indexing PST Files Using Outlook 0
kburrows Outlook Classic - JPG files are corrupted when opened or saved Using Outlook 3
chummy Open multiple Hyperlinks to download files Outlook VBA and Custom Forms 3
B Outlook 365 Files Being Created with Logging OFF Using Outlook 0
F Outlook 365 Can I attach 2 files to to post? Using Outlook 1
K Protected View - Files fail, no banner Using Outlook 4
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
Commodore MHT files (from "View in browser") Using Outlook 7
J What are .PST.db and .PST.db.journal Files? Using Outlook 2
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
N Two .pst files on one computer both with contacts? Using Outlook 9
V Carbonite not backing up .ost files Using Outlook 7
DoctorJellybean Import accounts\files Using Outlook 1
O Outlook 2016 has "Outlook 2015" files Using Outlook 2
R How can I access my emails from corrupt offline files of MS Outlook ? Using Outlook 1
O Any decent tool to compare .pst files? Using Outlook 2
