Outlook Rules and OFT templates
  • Thread starter Thread starter Reddogclub
Reddogclub
HI all,
I am trying to get some rules to work since our mail services team has turn
off the port to allow out-of-office rules to respond to outside email.
I created client only based rules that stated that a rule from a specific
email address will respond with this specific template. When I test this
rule, an INBOX0xx oft file is created for each response. Is there a reason
this is happening or did I need to do something different with the rule?
I also set-up a second rule that states that anything coming into this
machine will get responded with this specific template. The same thing
happens here.
It is my understanding that client based rules will only respond to the same
email address once a day upon login. If the outlook mailbox is not logged off
at least once a day, it will not respond.
Any thoughts on how to get past or fix these issues?
Thanks for your help.
Justine
The "respond with specific template" action requires an .oft file. Where is
the template stored that the rule uses? And where are the extra .oft files
being created.
The respond-once limit is necessary to prevent mail storms. If you want
other behavior, you'll have to move away from rules into VBA or add-in code.
Sue Mosher
"Reddogclub" <Reddogclub> wrote in message
news:2E594408-A8B7-41B7-88B1-60A038058821@microsoft.com...
> HI all,
> turn
> happens here.
> same
> off
> Justine
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
D Outlook Rules Using Outlook 1
Gunny NFOhiway Outlook PST file and Rules Using Outlook 1
M Outlook 2016 Rules Not Working Automatically Using Outlook 5
A outlook 2007 how to chcek all rules ? Outlook VBA and Custom Forms 2
J Outlook Rules not show Master Category List Using Outlook.com accounts in Outlook 4
R Outlook rules Using Outlook 3
M Outlook 2007 IMAP Account Rules Issues Using Outlook 3
D Outlook Rules - How to use a variable in the subject condition Outlook VBA and Custom Forms 9
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
J Outlook rules and alternatives Using Outlook 2
Rupert Dragwater How to delete old rules and create new in Outlook 2013 Using Outlook 12
H Using Outlook Rules to search for NewLines in message body Using Outlook 1
R Outlook - alternatives to Rules / Junk? Using Outlook 5
R Outlook 2013 - IMAP & Rules Broken Using Outlook 1
D Trying to repair Outlook rules Using Outlook 5
V Importing Rules in Outlook 2013 Using Outlook 2
T Adding text to forwarding rules in Outlook 2010 Using Outlook 1
T Adding tex to forwarding rules in Outlook 2010 Exchange Server Administration 1
D Outlook 2010 Rules: fwd meeting invitation results in winmail.dat not .ics Using Outlook 4
M Outlook 2010 IMAP rules occasionaly stop working Using Outlook 4
kburrows Smartphones, Outlook and Rules Using Outlook 0
W Fwd Outlook incomming messages to usb port after Rules and alerts applied Using Outlook 0
P Outlook 2013 rules -- not working reliably -- moving messages to wrong boxes Using Outlook 0
J Outlook 2013 - Rules and Alerts for POP3/IMAP Accounts Using Outlook 1
S Outlook 2010: Message Rules come back next time I restart Outlook Using Outlook 0
D Unable to transfer rules from one Outlook computer to another Using Outlook 5
R Outlook 2013 Rules not working Using Outlook 1
S Outlook 2013 - All rules simply delete the email Using Outlook 1
M Rules in Outlook 2013 Exchange Server Administration 9
K Outlook Cached Mode - can't create rules to move email to another mailbox Using Outlook 2
J Outlook rules help Using Outlook 1
J Outlook - rules and Alerts Using Outlook 1
V Outlook 2010 non working rules Using Outlook 1
M Rules & Alerts not appearing in the File Tab (outlook 2010) Using Outlook 1
