Delete Outlook subfolders using vba ?
  • Thread starter Thread starter Pjd007
P
Pjd007
I have a secondary mailbox in Outlook 2003 which has a top level folder
(ie. not the inbox) that has a subfolder containing a number of other
subfolders, some these subfolders have another subfolder which I want
to delete.
The folder I want to delete has the same name but is located in
multiple subfolders of the top level folder so I want to be able to
automate deletion of these folders as there is a large number of them.
I hope that's clear !
Can someone recommend a way to do this as it will be very time
consuming to do it manually.
Pjd007
This demonstrates how to loop recursively through your folder, maybe that
helps you get started:
http://www.vboffice.net/en/developers/looping-recursively-through-folders-and-subfolders
Best regards
Michael Bauer
Am Wed, 6 May 2009 13:07:08 +0100 schrieb Pjd007:
> Hi,
> to delete.
> Thanks.
N Outlook 2010 "permanently delete all the items and subfolders" not working Using Outlook 3
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
D Delete Outlook emails from MS server Using Outlook 17
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
Horsepower Cannot delete gmail in iPhone Outlook outbox Using Outlook 1
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
R Outlook 365 update sets delete from server flag Using Outlook 1
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
C Outlook 2016 cannot delete, email showing in root Exchange Server Administration 5
B Outlook 2016: Can't delete default calendar but I don't use it Using Outlook 7
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
makinmyway Bulk Delete Contacts in iOS Outlook App Using Outlook 4
Diane Poremsky Delete an Outlook Group Using Outlook 0
L Outlook 2007 Delete Email Addresses Using Outlook 19
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Axel_pup Outlook 2013 repositions list after delete Using Outlook 2
C Delete lines in Outlook Outlook VBA and Custom Forms 4
Rupert Dragwater How to delete old rules and create new in Outlook 2013 Using Outlook 12
UncleBill Unable to delete items from gmail IMAP Trash using Outlook 2010 Outlook VBA and Custom Forms 5
G Moving "Delete" button on Outlook for Mac Using Outlook 1
M Can't delete imap email from Outlook 2013 Using Outlook 4
T Cannot Delete a contact in Outlook Shared Contact List Using Outlook 0
L Outlook 2007 Delete and Paste Between Fields Using Outlook 25
L Outlook Contact Field Delete Using Outlook 7
mikolajek Outlook 2013 IMAP actions (message move / delete etc.) significantly delayed Using Outlook 0
F Outlook 2010 unable to delete emails from scanner Using Outlook 1
P Unable to delete custom forms in outlook 2010 Using Outlook 1
E Want Outlook to delete tenative calendar entries when invite is deleted Using Outlook 3
S Outlook 2013 - All rules simply delete the email Using Outlook 1
W Cannot delete Outlook 2010 data file Using Outlook 1
S can't delete duplicate account under Outlook 2007 (Win 7) Using Outlook 16
D Outlook 2010 registry hack - delete emails - Google Apps Using Outlook 0
H Hotmail set not to delete from other accounts, but did. Settings in Outlook? Using Outlook.com accounts in Outlook 0
L How can I delete stationery from Actions, New Mail Message Using in outlook 2007? Using Outlook 6
H How to delete Messages in ascending order - Outlook 2010 Using Outlook 4
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
R Outlook eating up delete keypress Options Outlook VBA and Custom Forms 6
U Not able to delete Add-in button from multiple Outlook Explorer Outlook VBA and Custom Forms 1
F Outlook 2021 Inbox delete icon missing Using Outlook 5
T Cannot delete a calendar Using Outlook 0
A Outlook 365 Delete entries in title field, address book Using Outlook 0
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
