Reply with picture in body of message
  • Thread starter Thread starter Maxx
Maxx
I'd like to mofify this code (if possible) so that it includes the picture
that is in the body of the e-mail.
Sub ReplyDelightful()
Set objInsp = Application.ActiveInspector
If Not objInsp Is Nothing Then
Set objItem = objInsp.CurrentItem
If objItem.Class = olMail Then
Set objReply = objItem.Reply
With objReply
> Body = "Delightful!" & vbCrLf & vbCrLf & "Thanks," & vbCrLf
& "David" & vbCrLf & .Body
> Display
If this is an HTML message try using HTMLBody. Body will only return the
plain text rendering of the message.
"Maxx" <Maxx@Leggs.com> wrote in message
news:Ok2a22W4JHA.140@TK2MSFTNGP03.phx.gbl...
> With objReply
> .Body = "Delightful!" & vbCrLf & vbCrLf & "Thanks," &
> vbCrLf & "David" & vbCrLf & .Body
> .Display
> End With
> End If
> End If
> End Sub
Ken,
THank you very much for your help.
David
news:edNZogu4JHA.1416@TK2MSFTNGP04.phx.gbl...
> > picture that is in the body of the e-mail.
> > With objReply
> > .Display
> > End With
> > End If
> > End If
>> End Sub
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
T In-line reply style in Outlook II Outlook VBA and Custom Forms 1
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
Vijay Reply all by attachment name Using Outlook 10
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
