Outlook volume exceeded
Fre
I would be greatfull if you could help me with this problem :
By mistake I sent with outlook 19 GB as attachment to an @mailadress.
Of course I got the message " outlook volume exceeded".
In outlook is actually 22 GB whereas the maximum is about 2O GB I think.
Microsoft adviced me to delete messages by shift + del which I did.
Outlook does not react. Shift + del comes always back.
Is there any software programm to increase volume outlook temporaly or an other solution ?
Many thanks in advance from Belgium for your advice and help.
Fre
Fre
Thanks for reply
I don't see the wrong message of 19 GB I sent. Nor in sent items neither in out items.Probably Outlook blocked.
I got albays the same " outlook volume exceeded make shift + del " which I did several times but the same comes always back.
Kindest regards
Freddy
Thanks very much Diana !
I think you understood the problem very well.
I will try it .
I do hope that blocked outlook will react on this reg. programm.
Keep you informed withing a few days.
Best regards
Freddy
hi Diane,
Very happy to write you the problem has been solved.
Many thanks
Freddy
H Downloading Outlook 2010 from Volume Licensing Centre problem Using Outlook 1
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 5
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 23
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
J Outlook troubleshooting/logging - option grayed out Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
B Outlook or iPhone turning tabs into spaces in Outlook Notes Using Outlook 1
P newly installed Office 365 includes OLD Outlook Using Outlook 6
R Outlook ribbon menu default? Using Outlook 7
H Spam email in Gmail not visible in Outlook Using Outlook 3
J How to transfer Win 10 Outlook to new Windows 11 pc? Using Outlook 15
G Reduce whitespace in Outlook desktop Contact Cards display Using Outlook 3
C Outlook classic via 365 Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
S Repair Outlook Using Outlook 7
