Error code 0x8004102A Error With Send/Receive
steq184
I have got Outlook 2010 and I am having the same error message everytime I send/receive, I have 4 email accounts but it is the same one all the time athat is giving me the trouble.
I have looked in the Sync Issues folder and there are 105 issues there!!!
Can anyone take a look at the error code and offer some help please?
Your help greatly appreciated.
Here's a slimmed down copy of the error as only allowed to post 4000 characters in post:
16:14:20 Synchronizer Version 14.0.6106</SPAN></SPAN
16:14:20 Synchronizing Mailbox steve***@hotmail.co.uk'</SPAN></SPAN
16:14:20 Synchronizing Hierarchy</SPAN></SPAN
16:14:20 1 folder(s) updated in online store</SPAN></SPAN
16:15:05 Network operation failed</SPAN
16:15:05 </SPAN></SPAN
*Request* </SPAN></SPAN
16:15:05 16:14:22:0843</SPAN></SPAN
16:15:05 GET</SPAN></SPAN
16:15:05 http://</SPAN></SPAN
16:15:05 Account</SPAN></SPAN
*Response* </SPAN></SPAN
16:15:05 16:14:22:0812</SPAN></SPAN
16:15:05 Synchronization error.</SPAN
16:15:05 Folder Collection Sync Key: 0{fb7027a9-dcc9-4ec4-b839-6e2ed05c1b36}978</SPAN></SPAN
16:15:05 Message Collection Sync Key: 0{364536a3-64dc-4e83-be3e-31b5754bf87d}978</SPAN></SPAN
16:15:06 Error with Send/Receive.</SPAN
16:15:06 There was an error synchronizing your folder hierarchy.The network connection is unavailable or interrupted. Please try again later.</SPAN
16:15:06 Synchronizing server changes in folder 'Steve's calendar'</SPAN></SPAN
16:15:06 Synchronizing server changes in folder 'Contacts'</SPAN></SPAN
16:15:06 </SPAN></SPAN
16:15:06 16:15:06:0359</SPAN></SPAN
16:15:06 POST</SPAN></SPAN
16:15:06 http://</SPAN></SPAN
16:15:06 contacts.msn.com</SPAN></SPAN
16:15:06 /ABService/ABService.asmx</SPAN></SPAN
</LASTCHANGE><DELTASONLY></DELTASONLY></ABFINDALL></SPAN></SPAN>16:15:06 </SPAN></SPAN
16:15:06 16:15:06:0687</SPAN></SPAN
16:15:06 HTTP/1.1 500 Internal Server Error</SPAN></SPAN
Cache-Control: private</SPAN></SPAN
16:15:06 <soap:Envelope ? target="_blank" http: envelope soap schemas.xmlsoap.org xmlns:soap="</SPAN><a href=">http://schemas.xmlsoap.org/soap/envelope/</A>"
<soap:Body><soap:Fault></FAULTSTRING><FAULTACTOR></SPAN>http://www.msn.com/webservices/AddressBook/ABFindAll</FAULTACTOR><DETAIL><ERRORCODE< a> xmlns="http://www.msn.com</SPAN></SPAN
****************</SPAN></SPAN
16:15:06 There was an error synchronizing a contacts folder. Error : 80041004.</SPAN
16:15:06 Synchronizing server changes in folder 'Drafts'</SPAN></SPAN
16:15:06 Synchronizing server changes in folder 'Inbox'</SPAN></SPAN
16:15:08 Synchronizing server changes in folder 'Chris ***'</SPAN></SPAN
16:15:08 Synchronizing server changes in folder 'SB'</SPAN></SPAN
16:15:08 Synchronizing server changes in folder 'POP'</SPAN></SPAN
16:15:08 Synchronizing server changes in folder 'Sent Items'</SPAN></SPAN
16:15:08 Synchronizing server changes in folder 'Deleted Items'</SPAN></SPAN
16:15:08 Synchronizing server changes in folder 'Junk E-mail'</SPAN></SPAN
16:15:08 Done</SPAN></SPAN>
</soap:Fault></soap:Body></soap:Envelope>
  1. Remove the email account
  2. Close Outlook
  3. Delete the .OST file for the problematic email account
  4. Re-open Outlook
  5. Add the email account ( Using Outlook Hotmail COnnector )
  6. Once finished, close and re-open Outlook
  7. Change the Download Mode for this email account to download only headers from "Define Send/Receive groups"
  8. CLose and re-open Outlook.
Your issue will be FIXED!!!!!
This is a known issue with Outlook Hotmail Connector and not sure whether Microsoft fix it or Not
Did you empty the safe and blocked lists on both the server and in outlook? underscores and other non-alphanumeric characters are known to cause this error. Also, don't use underscores or dashes in folder names.
C Error Code -3253 Outlook for MAC Using Outlook 0
D Outbox will not send, error code 0X800CCC78 with 550 sender restricted. Using Outlook 3
S Error code 3260 Using Outlook 6
C compile error on previously functioning code outlook 2003 windows Outlook VBA and Custom Forms 1
J I'm getting an error code 8 when try to access my exchange account Using Outlook 6
E Outlook Code Problem On Email Moves - Error -2147221233 Outlook VBA and Custom Forms 2
K Outlook 2007 Error Code 0x80040607 Using Outlook 10
Q Error code appears when I try to send e mail Using Outlook 2
C receiving error code 0x80042108 Using Outlook 9
G Forms error on iCloud calendar Using Outlook 15
Sandgroper48 Automation Error Outlook VBA and Custom Forms 12
G Error - "Customized functionality in this application will not work because the certificate" Outlook VBA and Custom Forms 1
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
V Outlook Error The Attempted operation Failed. An Object Could Not be found Outlook VBA and Custom Forms 0
T Event Error on non existent Event. Using Outlook 2
A Links in email getting error message about group policy Using Outlook 4
Cathy Rhone Mail merge error message Using Outlook 1
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 4
