Custom Forms for Emails
mh505
I have the most vexing problem and maybe I am missing something; but an intensive google search has not given any results. So I need to address myself to the experts ::))
Here is the situation:
Some time ago, I created and published a simple custom form for Email; not realizing that it wasn't really necessary. Now, however, when I want to take it away from its location (Personal Forms Library) I no longer can forward or reply to mails without getting the message "The form you selected could not be displayed". The reason I want to delete this custom form is the email account that is associated with it which overwrites the definition under 'Tools, E-mail accounts' so that no matter which EMail account if want as the default, I always get the one from this form.
I therefore figure I need to find a way to disassociate this form but have not found the means to do this (I tried both the DocMessageClass and FormSwap utilities; but to no avail).
Any ideas? Appreciate your help !
Thanks for the prompt reply ! Yes, the form cache was among the first things I tried but it did not solve the problem. As said before, I'm working on this for a while and so far the only thing I've come up with is to republish the form with the account that I have designated to be the default under 'Tools, Email accounts'. But it is not a very elegant solution.
I should have hoped that there is a way to "extricate" as it were a given custom form so that the system no longer needs it ....
Did you uninstall it? (using forms manager)
Did you set it as the default for replies and forward? I'm not even sure if that was possible to do, but it sounds like what happened.
Well, that's the whole point. Wehn I uninstall - that is: delete - the form I can no longer reply or forward. And if I reinstall - that is republish - it, it reverts back to the default account that is defined by it.
Clearly, there must be a link somewhere so that Outlook looks for that form when replying and forwarding (but not when creating a new mail). And if I knew how that link or association came about I probably could now undo it. But I'm not aware of making it the default for anything nor do I think that is is possible
S Adding Custom Forms Outlook VBA and Custom Forms 4
B Outlook Custom forms Using Outlook 0
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
Diane Poremsky Designing Custom Outlook Forms Using Outlook 0
Diane Poremsky Publishing Custom Forms Using Outlook 0
Nick Truscott Lost custom forms after moving mailbox Outlook VBA and Custom Forms 3
H Lost Custom Forms when we replaced Exchange Server Outlook VBA and Custom Forms 3
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
LarryH Custom Fields & Forms Using Outlook 3
P Creating custom contact forms Using Outlook 2
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
M Workarounds for sharing custom Outlook 2007 forms? Using Outlook 3
P Unable to delete custom forms in outlook 2010 Using Outlook 1
G Office Profession Plus 2010 is not working for custom forms Using Outlook 3
O Outlook custom forms (2003) Using Outlook 5
A Outlook 2013 corrupting custom forms? Using Outlook 34
J Custom Forms Don't Always Auto-Forward From Public Folder Using Outlook 0
K Custom Forms - Blank Message Received! Using Outlook 1
T Custom Forms Problem Outlook VBA and Custom Forms 1
K Find vs. custom forms Outlook VBA and Custom Forms 2
T Custom Contact Forms and User Properties Outlook VBA and Custom Forms 2
B Macros have been disabled error Message with Custom forms Outlook VBA and Custom Forms 17
G Custom Forms: Attachment to be included in Reply Outlook VBA and Custom Forms 1
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
Q More than one Notes section in custom contact forms Outlook VBA and Custom Forms 1
O custom forms Outlook VBA and Custom Forms 2
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
