Add small calendar to navigation
michaeljc70
Is there a way to add a small calendar to the navigation pane in mail? I frequently need to look at a monthly calendar and have room there. If not, is there somewhere else I can put a small monthly calendar while in email?
T Add Account Using Outlook 1
