Outlook on a machine w/multiple LAN connections
Sarge USMC
Outlook 2013 64 bit
I have 2 active LAN connections on this machine for work. The customer Lan does not allow
access to my pop/smtp. So I set the preferred network connection to be the one that does,
but it's not working because Outlook is returning POP errors every time it checks for new mail.
I can't get Outlook 03 to "see" the preferred network connection that I have set.
Is there a setting from within Outlook that needs to be changed?? What am I missing here?
Semper Fi!
Outlook uses the lan settings in IE. The only choices you can set in Outlook are in More Settings:
The only way to make Outlook use a specific connection is if you can set up a dial up networking connection for the correct connection and keep outlook offline.
B Outlook 2003 locks me out of virtual machine Using Outlook 1
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 5
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 23
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
P 3 of 5 PST files don't install from d:\outlook but only from D:\ Using Outlook 7
HarvMan January Windows 10 preview update force installs new Outlook Using Outlook 1
J Outlook troubleshooting/logging - option grayed out Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
B Outlook or iPhone turning tabs into spaces in Outlook Notes Using Outlook 1
P newly installed Office 365 includes OLD Outlook Using Outlook 6
R Outlook ribbon menu default? Using Outlook 7
H Spam email in Gmail not visible in Outlook Using Outlook 3
J How to transfer Win 10 Outlook to new Windows 11 pc? Using Outlook 15
G Reduce whitespace in Outlook desktop Contact Cards display Using Outlook 3
C Outlook classic via 365 Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
S Repair Outlook Using Outlook 7
