Sound when receiveing mail.
desgnr
Outlook 2013 32 bit
In Outlook 2013 i selected in Options Play a sound in Message arrival.
In Control Panel,Sounds i selected the Wav file i want to play & installed it into the Windows,Media folder. then i selected it in NEW MAIL NOTIFICATION & also in DESKTOP MAIL NOTIFICATION.
I tested it & it plays.
Now when i use Outlook it still Plays the default sound.
How can i get my sound to play ?
Y Are there any Sound options for Office 2016 specifcally for outlook? Using Outlook 0
B outlook 2010 - email sound notification Using Outlook 3
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
Rupert Dragwater Mail won't show as read Using Outlook 2
O Junk E-mail Options disabled(?) Using Outlook 3
E Replying to a plain text e-mail with HTML Using Outlook 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Exchange Server - Mail Delay Stamping Exchange Server Administration 0
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
P What is your strategy for dealing with SPAM and Junk Mail? Using Outlook 1
A manual rule sends mail to wrong folder Using Outlook 5
Cathy Rhone Mail merge error message Using Outlook 1
