OFT file problem
laaczy
I have edited our company's OFT to update it a bit. I have tried out a few things. After some tries, I have finished the new version.
But somehow some earlier changes are still existing in the file.
What I mean: there was a textbox which I have deleted. But the value check is somehow still active. I can even find it in the oft with a text editor. Some of the company's requesters got this error message and I don't know how to get rid of it.
Is there a way, to erase the history of an OFT file?
Thanks for your replys
Gabor
Did you change the version # on the properties tab when its opened in the forms designer? You should always increment the version # when you up a new update so everything uses the new version.
Yes, I have updated it too. Currently we only published it on our intranet site, and haven't uploaded it to the organizational forms, as we had it with the previous version.
What I don't understand is, why doesn't outlook delete every property of a field, as soon as I delete the field?
I can send you the oft in PM, and you show you the problem. I really need a solution.
The form displays the fields - the fields are still be published in the folder if they contained data - outlook won't destroy data. Turn off the reading pane and go to Field Chooser - at the bottom of the drop down is user-defined fields [this folder] delete the fields from the folder.
My problem is this(source code of the OFT):
I hope it is readable. There is no variable "cats" anymore, since I have deleted it weeks ago.
Any ideas?
M Why oft-file opens as outbox not as draft Outlook VBA and Custom Forms 4
H URL's don't work in .oft file Using Outlook 1
2 Create an email brochure - oft file? Using Outlook 3
D forward email with attachment using .oft Using Outlook 3
airtas oft templates not sending changes Using Outlook 2
J Outlook .oft files Using Outlook 5
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
W Broken Folder Loop - Outlook 2007 (.oft files) Using Outlook 2
C Custom .oft / Printing Issue(s) Using Outlook 1
V New problem, .oft extentions in Outlook 2013 Using Outlook 5
F CAN'T SAVE OUTLOOK 2010 E-MAIL TEMPLATE (.oft) Using Outlook 1
N How to automatically update all fields in an Outlook message template (OFT)? Using Outlook 9
R Outlook Rules and OFT templates Outlook VBA and Custom Forms 1
P how do I work with oft files in outlook 2007 Outlook VBA and Custom Forms 1
P outlook 2007 - custom buttoms with hyperlinks to oft files Outlook VBA and Custom Forms 1
J How do I send a completed .oft form? Outlook VBA and Custom Forms 4
O How will a new Exchange profile handle existing .ost file stored elsewhere? Using Outlook 4
R File not found when sending email with attached pdf file Using Outlook 2
Victor_50 Outlook 365 Extract all mail addresses and names from a pst file to csv. Using Outlook 3
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
T Cannot open .pst file Using Outlook 2
D DB/Object/Record vs File/List/Range Terminology Outlook VBA and Custom Forms 0
W Outlook 365 File access denied attempting to import .pst Using Outlook 6
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
DoctorJellybean Use OST file location for fresh installation? Using Outlook 1
HarvMan Exporting IMAP OST file to PST Using Outlook 5
P File Picker for attachment Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
N File Picker for attachment Outlook VBA and Custom Forms 2
L Article on merging pst file Using Outlook 1
