Add to Right Click Menu
LMS
I found the following code that you put in ThisOutlookSession that adds to the right click menu the reply to an email that you select. Is there something to do in this code where it can add a macro that I use, or when I create a new Useform that is not related to a Module, in the ThisOutlookSesssion I add code to the ThisOutlookSession ..for example:
Public Sub runthis72()
Dim frm As New UserForm71
frm.Show
And this code runs the Userform71. So can I add the runthis72 to the big code I will post. so it shows up in the right click menu?
Private Sub Application_ItemContextMenuDisplay( _
ByVal CommandBar As Office.CommandBar, _
ByVal Selection As Selection)
Dim objButton As CommandBarButton
Dim intButtonIndex As Integer
Dim intCounter As Integer
On Error GoTo ErrRoutine
' Ensure we have only one item selected.
If Selection.Count = 1 Then
' Ensure we have a MailItem selected.
If Selection.Item(1).Class = olMail Then
' Find the location of the Reply To All button.
For intCounter = 1 To CommandBar.Controls.Count
If CommandBar.Controls(intCounter).ID = 355 Then
intButtonIndex = intCounter
Exit For
' If we have a Reply To All button in the
' context menu, add a new button to support
' the ReplyToNoncopied routine.
If intButtonIndex <> 0 Then
' Create a new menu item and place it
' just after the Reply To All button
Set objButton = CommandBar.Controls.Add( _
msoControlButton, , , intButtonIndex)
' Configure the menu item.
With objButton
.Style = msoButtonIconAndCaption
.Caption = "Repl&y to Non-copied"
.Parameter = Selection.Item(1).EntryID
.FaceId = 355
' If you place this sample in a class module
' other than ThisOutlookSession, update this
' line of code to ensure that the OnAction
' property contains the correct project,
' class, and routine name.
.OnAction = "Project1.ThisOutlookSession.ReplyToNoncopied"
EndRoutine:
On Error GoTo 0
' Place clean-up code here.
ErrRoutine:
MsgBox Err.Number & " - " & Err.Description, _
vbOKOnly Or vbCritical, _
"Application_ItemContextMenuDisplay"
GoTo EndRoutine
I changed "If Selection.Item(1).Class = olMail Then" to "If Selection.Item(1).Class = olContact Then" and changed ".OnAction = "Project1.ThisOutlookSession.ReplyToNoncopied" to ".OnAction = "Project1.ThisOutlookSession.runthis72", and when I select a contact, it opens the Userform from the runthis72....
But, I change the code title the top, and of course the caption, and a different runthis48, it does not show up as a second one......so can we do that? And if I select more than one contact, it does not show the additional on the right click menu....so can we do that?
Believe it or not, I added to the code
Dim objButton2 As CommandBarButton and
With objButton2
.Caption = "LinkedIn Marketing E-Mails"
.FaceId = 355
And it added the next runthis72 for the other userform......
So need to know what to change so it does the same when I select more than one contact.
you need to set up the selection and check each obj in the selection, something like this:
    Dim Selection As Selection
    Dim obj As Object
    For Each obj In Selection
        If obj.Class = olContact Then
            Set objContact = obj
            With objContact
for each obj in selection
Thanks much. Can you tell where to put what and what to delete as I repeat, I only do what you show me.
I have no idea where it goes. :) Maybe replace the code that checks for the selection count?
As a favor, can you please copy my code, make the changes and post it, as I have no idea how to do it.
Thanks to the Smart Woman!!!
Seriously, I have no idea and I'm just guessing. :) You need to try something and see if it works. It may not be possible, I don't know.
Dim obj As Object
If obj.Class = olMail Then
Set objmail = obj '(what are you calling the mail object?)
With objmail
'do all this stuff
Exit For
' when do, loop to the next
'rest of your code here
N Right-click an address -&gt; add to BCM? [OL2007] BCM (Business Contact Manager) 1
N Adding 'Add To Business Contacts' when right-clicking an email add BCM (Business Contact Manager) 2
T Add Account Using Outlook 1
