Rule starting a VB macro against incoming email
Guy
I have a rule looking at the Subject line for a certain phrase. When an email comes into Outlook the rule starts a macro with the following name:
Sub Check_For_EPDMnumbers(Item As Outlook.MailItem)
I cannot get this routine to run against the email that triggered the rule. It runs against the email sitting at the top of the inbox which is selected. The incoming email does not appear in the Inbox until the macro finishes and even then its not selected. How do I select/parse on an email that does not appear in the Inbox, but triggered the macro?
If I use this code - Set olMail = Application.ActiveExplorer().Selection(1) it uses the selected email in Outlook. But the email I need to parse is not showing in the Inbox - how do I attach to something that has not appeared in the Inbox yet, but has tripped the rule and therefore the macro?
Thx.
CWM330 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
