Find related messages to sender
Bob Narindra
Outlook 2013 64 bit
I would like to create a macro button that is available when a message is selected.
I would like it to search the following: fromattachFull1385sender email) OR toattachFull1384sender email)
Everything I have found on Outlook searches all messages from a sender. However, I want to search all messages to a sender also.
Can someone help me out with regards to creating this macro?
Unfortunately I don't have a macro as such. It is just an available command in the ribbon called, "Messages from Sender"
for some reason that code I put got corrupted in the first email. Here is what it should be...
if you type this into the Outlook search..
to:name@email.com OR from:name@email.com
I would just like a button to do the same thing.
Thank you for the link. Will that search to OR from the contact name?
Please ignore - I guess I should read the entire page to see the macro below it. Thanks - that was exactly what I was looking for.
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
F Disable "Find related messages" Using Outlook 1
D Outlook 2007 Find All Related and Messages From Sender not working Using Outlook 3
B Find Related Emails to sender Using Outlook 1
Bardiferous Weird Contacts Behavior - Can't find any in any address book, but they're in there Using Outlook 3
J search doesn't find anything Using Outlook 1
M Issues with templates - unable to find in old web app Using Outlook 3
Witzker How to find all emails from and to a contact in OL 2019 Using Outlook 6
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
B Search: Cannot find which Folder Contains a Message Using Outlook 3
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
H "Advanced find: column for full folder path? Using Outlook 1
C Find all deleted recurrence appointments Outlook VBA and Custom Forms 4
mrje1 Is there a Find and Replace feature in Outlook 2016? Using Outlook 4
G Can't find contacts entered Using Outlook 0
Connie Boyer Exporting Outlook calendar/find next repeating meeting Using Outlook 3
RBLampert Outlook "can't find" my e-mail server to receive messages Using Outlook 22
M Can't find messages Using Outlook 4
Diane Poremsky Find the Distribution Lists a Contact Belongs to Using Outlook 0
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
thomas zaleski Cannot find the Sending FOlder Using Outlook 2
J Find and Highlight text in outlook Outlook VBA and Custom Forms 4
J Outlook Mailbox cleanup; any way to change limit to find items older 999 days? Exchange Server Administration 2
Jennifer Murphy Can't delete or even find task attachment Using Outlook 1
K Re: Use Instant search to find messages from a contact Outlook VBA and Custom Forms 6
Andrew Hawkins "Advanced Find" Using Outlook 1
M BCM 2007 Can't find SS2012Express Using Outlook 2
O Outlook 2013 contacts - Where to find "Display as"-field Using Outlook 2
C Cant find emails after moving pst Using Outlook 1
G Find Organizer of appointment Using Outlook 2
