Outlook 2007 Find All Related and Messages From Sender not working
dnl
I am using Outlook 2007 installed on Win7. I found that Find All Related Messages, and Find All Messages From Sender not working. I have tryed to change the Outlook profile and rebuit the index in data file (Search option) but it is not resolved.
Please give me a recommendation.
Thanks for helps.
I'm assuming because you have windows 7, that you haven't disabled Windows Search.
What happens when you try it? Does it work for any messages? Does instant search work?
Did you try running repair on the office install? (Control panel, add / remove programs - more info here: How to Repair Your Office or Outlook Installation - Slipstick Systems)
Dear Diane Poremsky,
No thing is replied when I try to make a search by a right click on a any message. Instant search also not working. But everything is OK when I run Outlook in safe mode.
I have tried to repair the outlook but it can not be resolved.
Window Search is currently working. How can I disable Window Search ?
Did you mean that Outlook and Window Search can not working together?
Thank you for your help.
C I have purchased Outlook 2007, now I find out that I need it with BCM (Business Contact Manager) 3
A Outlook 2007 ca+n't find bcm BCM (Business Contact Manager) 1
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
