Grouping emails using "From" causes a None Category
Anita Evans
I have a user who likes to group emails by from. However, when doing so, two groups are created: None and the User's Name. I'm not sure why None is showing up because when I look at the individual emails, the From is the same as the one under the user's name. How can "none" be the right category? Would sending on behalf cause this? There is no indication on the email that it was on behalf of the user from that I could see on the screen.
We are using: Windows 7, Outlook 2010 and the Outlook mailbox is synced with an iPhone.
Thanks so much! Anita Evans, Technical Trainer, Foster Pepper
Could those be messages you sent?
Hi Diane! Thanks so much for responding so quickly.
Well both groups: "None" and "User Name" are from him, so not sure why they are not coming together as one group.
The user has two places in the Inbox where his email is grouping when using the "From" -- his own name and "none." What would I or could I look at in those messages to see what Outlook sees as a none category, when clearly the email is from him?
It's not adding the From account on sent items from some reason - it happens occasionally with imap accounts. It doesn't affect anything but the From field appears blank.
Hi Diane!
So, the user is asking me now if there is a solution to this issue. Would it happen because he's using Reply All or Forwarding an email?
I'm not aware of a way to fix it as those fields are read only. If only messages that were reply all or forwarded are affected, then yes, it's a factor, but I don't think it makes a difference. Sending from different devices could be the cause.
D RTRIM a subject line for grouping purposes Outlook VBA and Custom Forms 1
S Calendar Daily Eventy Grouping Using Outlook 1
D Question re: Grouping by Due Date vs. Sorting by Due Date Using Outlook 1
J Outlook 2013 Sorting and grouping on 2 date fields Using Outlook 1
L Outlook 2007 Grouping Using Outlook 2
J Grouping email subjects by unique indentifier Using Outlook 1
A Outlook 365 Can I set up a Microsoft 365 account to capture emails sent and received from a comcast.net account? Using Outlook 7
T Emails with attachments from an alias are undeliverable to one of three aliases Using Outlook 2
B Arrows missing from Outlook emails vertical scrollbar Using Outlook 0
G Cannot receive emails from gmail account in Outlook 365 Using Outlook 1
D Amazon and some other emails not showing in Preview Pane Using Outlook 10
Retired Geek Outlook on MAC delete duplicate Sent emails Using Outlook 0
W Outlook 2021 Hanging on "Sending Emails" Using Outlook 3
J Action based on number of emails after sort by from Using Outlook 3
D Can't read some emails - text size too small. Using Outlook 2
R How to use VB .Net to send emails? Outlook VBA and Custom Forms 0
T Outlook is categorizing emails incorrectly Using Outlook 0
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
D Delete Outlook emails from MS server Using Outlook 17
A Flagged Emails highlighted in yellow Using Outlook 3
E Edit incoming emails to remove a certain sentence added by the "system" Using Outlook 1
J gmail and deleted emails. Using Outlook 0
U Outlook not responding when trying to print Emails Using Outlook 6
K mark emails with colour manually (like in thunderbird) Using Outlook 1
U Outlook on the iPhone cannot approve filtered Emails Using Outlook 0
B Move emails from one account to another Outlook VBA and Custom Forms 2
