VBA missing Stationery Picker.
elzopi
Outlook 2013 32 bit
I have some vba code that I started since Outlook 97, I have modified it through several versions all the way up to 2010, however, now I am at 2013 and it stopped working, I get an Error 91: Object variable with block variable not set.
Specifically this piece of code is the culprit in 2013:
set objCB=Application.
ActiveExplorer.Commandars.FindControl(, 5611)
This used to bring up the Stationery Picker menu.
Your help is greatly appreciated.
Is there any other option for the Stationery Picker for 2013?
N Redemption VBA basics...something's missing Using Outlook 0
