Questions On Crashing, Sluggish, and Configurations
Outlook 2016 64 bit
Loaded question I know - but I have several. First off I am using Office 2016 with 4 email accounts.
For years now Outlook will crash if I leave it open for several hours, I seem to be able to avoid it crashing if I refresh the inbox regularly throughout the day but if I let it sit for a few hours it will hang up when updating the folders and never sync. If I close it I am unable to relaunch Outlook, if I expand the taskbar by the clock I will see the Outlook icon greyed out. I then have to open task manager, end Outlook, go back to the task menu icon and hover over it for it to go away THEN relaunch Outlook. This has been going on for years.
It does seem to be getting slower and slower when refreshing the inbox the send/receive tasks can take 30+ seconds. Can I do anything to clean it up? If I view the app data Outlook folder I have 5 data files for 4 email accounts (one is a duplicate) I have tried deleting the duplicate but it regenerates itself upon reopening Outlook. Another data file for one of the email accounts has a (2) in the name, if I remove the (2) it just abandons the file and regenerates another one with the (2) in the name upon reopening Outlook.
The largest two email account data files are around 1GB in size. I like seeing my email accounts case sensitive with some capital letters in Outlook (on the left side menus) so I did edit the data file names years ago with the proper capital letters. However one account is stubborn and if I rename it with caps (not changing the spelling) it does not reflect in Outlook...the email account just remains all lowercase on the left menu. Why would it work for all the others and not one? This is also the account that regenerates a duplicate data file, but I tried editing the name of both the duplicates but it still does not reflect in Outlook.
I am unable to get the email account I want as default set, it used to be the default but now it says "The selected Outlook data file (.pst) format cannot be used. Outlook data files (.pst) must use the same format as offline Outlook data files (.ost) Select a matching Outlook data file (.pst) or turn off cache mode in the Account Settings". If I click the account settings for this email to disable cache mode it says "Your Outlook data file cannot be configured." and shows its directory path with the .ost extension. The confusing thing is all 4 of the email data files ARE .ost and the duplicate one is a .nst
o_O
Edit/Update: I was able to disable cached exchange mode on one of the duplicate accounts, which deleted the duplicate data file (.nst)
The other 3 accounts do not have an option to uncheck caching, they only have an option not to save copies of sent items. The settings page for them only brings up a dialog to compact the .ost file so I am not sure if this is because they are AOL & GMAIL accounts where the 1 that allowed me to disable cached exchange mode was an Outlook email (using my employers domain). Its the only one with a location as "Online" rather than a local directory.
I deleted all the files in the RoamCache folder, and emptied the Auto-Complete List in Outlook and it seems to sync the folder tasks a bit faster now (still takes around 10-15 seconds on a 200mbps connection).
A Autoarchive questions Using Outlook 2
S Mac Outlook 365 Questions Using Outlook 1
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 7
D Outlook for Android Questions Using Outlook 8
O flagging replies - several questions Using Outlook 2
P Moving PST file questions Using Outlook 3
Y PST file questions Using Outlook 1
D Questions related to usage of webpage in outlook Using Outlook 1
G Questions on creating Outlook forms Using Outlook 0
O x86 vs. x64 Sql Server 08 Dbase Questions BCM (Business Contact Manager) 2
Jennifer Murphy Questions about ANSI-Unicode PST conversion article Using Outlook 2
J Multiple Outlook questions Using Outlook 2
P Field option selection resulting into multiple questions BCM (Business Contact Manager) 0
S Questions about Calendar Notifications Using Outlook 1
H Couple of 2007 Calendar questions Using Outlook 1
K CPA - Office 2010 - 64 bit Questions Using Outlook 1
S Couple of questions related to calender Using Outlook 1
S Seperating email accounts, Syncronizing, and a few newbie questions Using Outlook 5
T Outlook 2010 Mutliple Exchange Accounts SET UP QUESTIONS Using Outlook 4
E Questions on the OutlookRibbonXCS example Outlook VBA and Custom Forms 4
T Ribbon Control questions Outlook VBA and Custom Forms 7
K Scraping outlook emails (2 questions) Outlook VBA and Custom Forms 1
H Outlook 365 issue getting details from embedded files, crashing routine Outlook VBA and Custom Forms 0
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
C Outlook (365) is crashing as soon as its opened Using Outlook 2
L Outlook Office 365 cached mode crashing Using Outlook 0
E Gmail crashing Outlook Using Outlook 2
C Outlook Crashing on Specific BCM Lead File BCM (Business Contact Manager) 2
J BCM Crashing with Add-in Enabled in User Mode BCM (Business Contact Manager) 2
F Difficult Oulook Crashing Problem Using Outlook 1
D outlook keeps crashing with cLucene error Using Outlook 2
J Checking PST File Keeps Crashing Using Outlook 2
U Need a help please Outlook 2007 crashing Using Outlook 2
P Was Helvetica crashing Outlook, now fix has messed up explorer Using Outlook 4
T BCM Crashing during search - 2007 edition BCM (Business Contact Manager) 3
Q Constant crashing BCM (Business Contact Manager) 2
P pasteface method crashing outlook Outlook VBA and Custom Forms 7
B RE: Outlook 2007 - SMS Link (mobile text) crashing outlook Outlook VBA and Custom Forms 1
N Outlook Has Become Sluggish Using Outlook 12
