Add an entry to a specific calendar
kevinvinv
Outlook 2021 64 bit
Hello everyone,
I bailed on Mac and came back to Outlook b/c I was sick of non business-class email... but now I have all sorts of whacky problems with outlook.
For starters... I have 3 calendars... how in the world do I make an entry on a specific calendar? On mac I would create an entry and there would be a drop down to place it on a specific calendar. How is that done back here in Windows land?
Thanks!!!!
T Add Account Using Outlook 1
