VBA Only works once then doesn't work
OakwoodBespoke
OS Version(s)
  1. Windows
Outlook 365 64 bit
Outlook version:     Office 365
Email type or host:    IMAP
I have found a VBA on another forum to reply to all in an email with attachments.
The fist time it worked perfectly, now it doesn't work, i tried on a different machine and it does the same.
I get the attached error
I'm guessing its something to do with trust centre but if have tried allowing all macros but still doesnt work
Your help with this would be much appreciated
Here is the code
Sub ReplyWithAttachments()
Dim oReply As Outlook.MailItem
Dim oItem As Object
Set oItem = GetCurrentItem()
If Not oItem Is Nothing Then
Set oReply = oItem.Reply
CopyAttachments oItem, oReply
oReply.Display
oItem.UnRead = False
Set oReply = Nothing
Set oItem = Nothing
Sub ReplyAllWithAttachments()
Dim oItem As Object
Set oReply = oItem.ReplyAll
oReply.Display
Set oItem = Nothing
Set objApp = Application
Case "Explorer"
Case "Inspector"
Set objApp = Nothing
End Function
Sub CopyAttachments(objSourceItem, objTargetItem)
Set fso = CreateObject("Scripting.FileSystemObject")
Set fldTemp = fso.GetSpecialFolder(2) ' TemporaryFolder
strPath = fldTemp.Path & "\"
For Each objAtt In objSourceItem.Attachments
strFile = strPath & objAtt.FileName
objAtt.SaveAsFile strFile
objTargetItem.Attachments.Add strFile, , , objAtt.DisplayName
fso.DeleteFile strFile
Set fldTemp = Nothing
Set fso = Nothing
Did you change the trust center settings then restart Outlook?
You need to have macro security set to the lowest setting during testing: Enable all macros. The macros will not work with the top two options that disable all macros or unsigned macros. You could choose the option Notification for all macros, then accept it each time you restart Outlook, however, because it's hard to sneak macros into Outlook (unlike in Word and Excel), allowing all macros is safe, especially during the testing phase. You can sign the macro when it is finished and change the macro security to notify.
To check your macro security, look in File > Options > Trust Center > Trust Center Settings. Change the Macro Settings.
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
D Using VBA to send Word document as body of message works in 2007, but not in 2003 Outlook VBA and Custom Forms 9
