Seeing mails after loosing access
homusubi
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    Windows 11 - Pro
Outlook version:     Outlook (new) 2025
Email type or host:    Not sure
I'm using the Outlook (new) for work and would like to see the emails that are stored locally.
The issue is that I lost access to my account and cannot login anymore. Basically, when opening Outlook (new) I see all mails, but there is a login pop-up that stops me from getting into my inbox.
I was wondering is it is possible to recover the mails from the cache of some other files stored locally. Any ideas? There are some important mails I would like to make a backup of.
Thanks in advance.
If you cancel the sign in dialog, does Outlook load? If you did nt enable offline cache, you need to sign into the account as nothing is stored locally.
Did you ever use classic Outlook to access the account? If yes, you may be able to recover the email from it.
e_a_g_l_e_p_i I can't believe what I am seeing when trying to install Outlook 2021 Using Outlook 9
S Seeing Custom Fields in Contacts (Outlook 2010) Using Outlook 0
F Seeing the recipient in sent emails Using Outlook 1
O BCM Dbase Issues (both not seeing dbase & not allowing restore for wrong owner BCM (Business Contact Manager) 2
Terry Sullivan Unwanted Duplicate E-Mails -- One with My Message and the Other Blank Using Outlook 0
S Sent e-mails roll back to previous draft state Using Outlook.com accounts in Outlook 2
A Forward mails with "FW:" or "RE:" in title Using Outlook 2
sjmo2 Change subject for new e-mails only. Outlook VBA and Custom Forms 2
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 13
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
T Search for incoming e-mails for a specified time range Using Outlook 1
F Outlook 2016 Junk E-Mails Using Outlook 5
RBLampert Invisible e-mails in Gmail accounts Using Outlook 0
I How to receive mails on behalf of when sent to group mail? Using Outlook 2
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
Thiago Manzano Copying E-mails to a folder on HD Using Outlook 1
A Processing Incoming E-mails with Macros Using Outlook 0
P Send mails by Gmail not shown in outlook Using Outlook 5
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
Karsten V invites from outside company arrives as regular mails Using Outlook 2
A Encrypting mails depending from the address Outlook VBA and Custom Forms 0
Yusufbodrum Highlighting selected mails in any folder Using Outlook 2
C Linking e-mails BCM (Business Contact Manager) 1
S Mails getting downloaded multiple times Using Outlook 1
K Macro doesn't recognize local mails from colleagues Outlook VBA and Custom Forms 2
I Delete e-mails from server Using Outlook 2
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T Cannot get pop3 mails to my Android and Outlook Exchange Server Administration 1
A 1 folder to see all new mails Using Outlook 1
A Contacts missing in imported mails Using Outlook 1
L Selected Contacts For E-Mails Using Outlook 19
L Move E-Mails to Another Folder Using Outlook 66
J Change Subject of 500 mails sitting in Outbox with Macro Using Outlook 6
H Duplicate E-mails and Wetransfer Using Outlook 4
V Need to add some text in subject while creating new mails - NEED VB CODINGS Using Outlook 4
