Adding another add-in to a project
Matt
I have developed two seperate add-ins for outlook (one has a button in
outlook, and one has a button in inspector windows). Both of the add-ins work
seperately and both work when they are both installed. What I would like to
do is combine them into one project so that I have just one installation
setup. What I tried to do was with one of the projects, I have included the
installation files for the other project (config, manifest, dll), and also
included the reg key entries. I also added the custom actions for the other
project. When I build the solution and install it I get no errors. The add-in
for the project loads and is functional but the one that I added to it says
it had a run time error at load (doesn't let me see error). Am I missing
anything that I should add or is there a simpler way to do this. Please
Advise.
K
Ken Slovak - [MVP - Outlook]
If it's going to be all one addin just add the functionality from addin 2 to
addin 1. Only one manifest, COM registration, handling of Extensibility
events. Just pull the meat from addin 2 and add that to addin 1. Compile it
all as one addin dll.
"Matt" <Matt> wrote in message
news:793D200F-AA9C-4AC8-9897-40C6B3D4D585@microsoft.com...
> Hello,
> work
> to
> the
> other
> add-in
> says
> Advise.
> Thanks
F Adding User Defined Field to another form Using Outlook 0
C Unable to expand ANY folders after adding another gmail account. 2007. Using Outlook 4
G Adding a contact to a specific folder Using Outlook 0
R Adding Userform Dropdown List items from names of subfolders on network drive Outlook VBA and Custom Forms 10
G Stop Outlook 365 adding meetings to calendar Using Outlook 2
G Removing old emails when adding accounts Using Outlook 3
D Contact Group - Adding Bulk Addresses Using Outlook 2
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
J Adding Reply & Delete to main toolbar? Using Outlook 0
T Outlook 2007 adding categories Using Outlook 15
Diane Poremsky Adding Emojis to Outlook's AutoCorrect Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
Lucylou Outlook 2013 Adding Outlook.com breaks profile, "Outlook not working" messag Using Outlook.com accounts in Outlook 1
C Adding Categories when Composing Email Using Outlook 1
stephenjones Adding a business account to Outlook Using Outlook 1
Chris Grew Adding 2nd Email Address BCM (Business Contact Manager) 3
