MailEnvelope not working in Excel 2007
  • Thread starter Thread starter lowspark
L
lowspark
Here is a simplified version of an email macro which works in 2003 but
not in 2007.
Sub SendEmail()
Sheets("Email").Select
Range("A1:L32").Select
ActiveWorkbook.EnvelopeVisible = True
With Application.ActiveSheet.MailEnvelope
With .Item
> Recipients.Add "may.tillis@kochind.com"
> DeleteAfterSubmit = True
> Send
If I set my internet options - Programs - Email to Microsoft Office
Outlook, it fails on this line:
with this error:
Run-time error '1004': Method 'EnvelopeVisible' of object '_Workbook'
failed
If I set my internet options - Programs - Email to Outlook Express, it
fails on this line:
with this error:
Run-time error '430': Class does not support Automation or does not
support expected interface
I have Excel 2007 installed and Outlook 2003 (not 2007) -- not sure if
that makes a difference.
I have scoured the web but cannot find any documentation of others
with this exact problem.
Any help or ideas will be greatly appreciated! thanks!!
Yes, it makes a difference. That feature requires matching versions of Excel
and Outlook. It doesn't work with Outlook Express at all.
Sue Mosher
"lowspark" <may.tillis@kochind.com> wrote in message
news:110285e3-c66c-4c6d-9c9c-1da0fda8167b@o6g2000yqj.googlegroups.com...
> not in 2007.
> Sub SendEmail()
> With .Item
> .Recipients.Add "may.tillis@kochind.com"
> .DeleteAfterSubmit = True
> .Send
> End With
> End With
> End Sub
> with this error:
> failed
> fails on this line:
> with this error:
> > Sue Mosher
Well, that did it! Thank you very much, that was exactly the answer I
was looking for!
J Getting MailEnvelope of a Word document does not work Outlook VBA and Custom Forms 2
P Outlook 2016 Working Offline Using Outlook 2
T SMTP suddenly quit working - password Reset Using Outlook.com accounts in Outlook 3
A Outlook 365 Outlook (part of 365) now working offline - argh Using Outlook 5
R Outlook Working off line Using Outlook 0
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
Commodore Automatic switch between working offline/online Using Outlook 4
F Searches are not working properly Using Outlook 1
Jennifer Murphy Spam filter not working Using Outlook 13
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
F KB4475563 stops VBS at forms working Outlook VBA and Custom Forms 3
D Archive by receive date not working Using Outlook 2
cricket1001 Shade non-working days in calendar Using Outlook 0
A rules not working Using Outlook 2
V Autocomplete not working on new email account Using Outlook 4
