Archive bit in email messages?
  • Thread starter Thread starter Sam
Sam
I've noticed that after an archive of email is made in outlook, then a mail from that archive is dragged back into a mail folder that that mail is never archived again.
Is there a flag or bit that is set on an email message that prevents it from being re-archived? Is there a way to un-flag that bit for mails?.
The Archive option moves mails, based on Modified Date, to a seperate pst
file
There is no flag set on the msg.
You can archive an Archive data file
"Sam" <smarrocco[at]ringsidecreative[dot]com> wrote in message
news:usxkcdgFKHA.4168@TK2MSFTNGP05.phx.gbl...
[quote title=DL wrote on Wed, 05 August 2009 18:54]The Archive option moves mails, based on Modified Date, to a seperate pst
file
Interesting. Then perhaps what is happening is that when a message is archived, it is touched (modified). Bringing it back into the system and attempting to archive it again fails because using a date of "modify everything older than today" is false because the file was archived today and therefore modified today?
BTW, I can confirm that this happens....I archived a folder, brought it back in and copied the messages back to their original folder. Any attempt to re-archive creates an archive with empty folders and no messages.
When a message is moved, whether from an archive folder or a normal folder,
the LastModificationTime date/time property is updated. Until the item is
aged to your archive specification it won't get archived again.
news:%23WEyXyiFKHA.4168@TK2MSFTNGP05.phx.gbl...
> moves mails, based on Modified Date, to a seperate pst file
kburrows Online Archive - Do Not Archive Tasks Using Outlook 1
L Why are some email automatically going to "archive" Using Outlook 2
HarvMan Archive Email Manually Using Outlook 1
P How did hacker cause link to delete and archive containing email? Using Outlook 6
D Archive by receive date not working Using Outlook 2
GregS Can't access archive file Using Outlook 5
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
S Moving Emails Between Archive Folders Using Outlook 1
M Multiple spurious empty folders appear in archive files Using Outlook 3
P Can't search Archive'd Tasks Using Outlook 0
C Merge two archive calendars Using Outlook 1
B Relocating archive.pst file Using Outlook 6
R Enable Office 365 Exchange Online Archive Using Outlook 0
R Enable Office 365 Exchange Online Archive Using Outlook 6
A Does Outlook import Gmail Archive? Using Outlook 1
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
K Different kind of issue related to creation of archive after one has been deleted Exchange Server Administration 1
skylark53 Archive a single Outlook 2013 folder tree Using Outlook 5
L Archive Shared Folders for all to Share Using Outlook 0
Z Manual archive of select folders Using Outlook 1
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
Jennifer Murphy Difference between export and archive? Using Outlook 10
D I can’t access my archive.pst Files Using Outlook 2
K Change the default Archive location via GPO in Outlook 2010 Using Outlook 3
G archive attribute for email attachments Using Outlook 2
S Create rule to effect archive only Using Outlook 4
O Importing pst, archive pst and address not working Using Outlook 17
J Auto-archive with Exchange account Using Outlook 2
D Add data in archive.pst to outlook.pst Using Outlook 4
J Outlook 2007 Archive Using Outlook 1
R [outlook-users] Messages won't archive Using Outlook 5
T Move archive file to new hard drive and still be ablse to access it Using Outlook 1
M Max size reached for archive folders Using Outlook 1
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
H Opening .PST archive files in Outlook 2007 Using Outlook 10
R Custom Archive code -- modify my code! Outlook VBA and Custom Forms 3
U "archive.pst cannot be opened" when archiving Using Outlook 4
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
