read receipts while processing emails
  • Thread starter Thread starter Trefor
Trefor
I am saving emails to an HTML file and then moving the file to another folder.
I am guessing at this point in my code (because I did not manage to see
which step):
olMail.UnRead = False
on one of the messages the code stopped because there was a prompt to send a
read receipt. How can I automatically send the read receipt or bypass the
message?
I know there is a global option to automatically send read receipts, I am
looking to see how I might be able to do this programmatically on each
message.
Trefor
It might be possible to bypass it by setting the ReadReceiptRequested
property of the MailItem to False.
Changing the global option doesn't work as that setting is stored in the
registry, and Outlook reads those settings only once at startup.
Best regards
Michael Bauer
Am Sat, 5 Sep 2009 03:37:02 -0700 schrieb Trefor:
folder.
> which step):
a
> message?
> message.
Michael,
Many thanks for you responce.
This is not make any difference:
olMail.ReadReceiptRequested = False
olMail.UnRead = False <---- still get a message requiring user
invention
I have just answered Yes and ticked the box to all take this answer
everytime and that works fine, of course this would need to be set at least
once on every machine this code is run on and if anyone resets it I and back
to where I started.
Trefor
> > Best regards
> Michael Bauer
> folder.
> > which step):
> a
> > message?
> > message.
What happens is you save the item after setting
olMail.ReadReceiptRequested = False?
Best regards
Michael Bauer
Am Sat, 5 Sep 2009 20:24:01 -0700 schrieb Trefor:
> Michael,
> invention
least
back
> to where I started.
Michael,
I will have to have another play and see. For now I have just said "yes" to
all in the global setting.
Thanks for your help.
Trefor
> > Best regards
> Michael Bauer
> > Michael,
> > invention
> least
> back
> > to where I started.
On the MAPI level (C++ or Delphi), you would need to call
IMessage.SetReadFlag() passing the SUPPRESS_RECEIPT flag.
Outlook Object Model won't let you do that, <plug> Redemption can do that -
use RDOMail.MarkRead method - see
http://www.dimastr.com/redemption/rdo/rdomail.htm </plug
Dmitry Streblechenko (MVP)
"Michael Bauer " <mb@mvps.org> wrote in message
news:2xsf1xz12ccl$.31kqjc8zxrpo$.dlg@40tude.net...
> > Best regards
> Michael Bauer
> folder.
> > which step):
> > send
> a
> > message?
> > message.
B Delete Read Receipts in Your Outlook Outlook VBA and Custom Forms 0
Rupert Dragwater Mail won't show as read Using Outlook 2
Dr. Demento Analogous Outlook code to read info into an array (or collection or whatever) Outlook VBA and Custom Forms 7
D Can't read some emails - text size too small. Using Outlook 2
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
