Move message skips messages when looping through mailbox
  • Thread starter Thread starter John_Ba
John_Ba
I'm trying to loop through a mailbox and display a form that chooses whether
to move the message to a different folder and which one to move it to.
For testing I have 2 messages in the mailbox. The problem is that if I choose
to move the firts message then the loop ignores the second message, however
if I don't move the first message then the second message is displayed.
If I run in debug mode with a breakpoint then the code works as expected.
Anybody have a good idea?
Set myOlApp = CreateObject("Outlook.Application")
Set myNameSpace = myOlApp.GetNamespace("MAPI")
Set myMailbox = myNameSpace.folders("Mailbox - RSP SWE DMSII Support")
Set myInbox = myMailbox.folders("Inbox")
Set AgentRS = OpenRS(myConn, "SELECT * FROM AgentsColleagues('" & USERCK
& "') ORDER BY Name")
Set AgentForm = New GetAgent
AgentForm.SetAgentList = AgentRS
AgentForm.SetFolderList = myMailbox
For Each myItem In myInbox.Items
myItem.Display
' Debug.Print myItem.UserProperties("Owned by")
AgentForm.Init = -1
AgentForm.Show
If AgentForm.AgentList.ListIndex > 0 Then
Set Owner = myItem.UserProperties.Add("Owned by", olText, True)
Owner.Value = AgentForm.AgentList
Set Action = myItem.UserProperties.Add("Action", olText, True)
Action.Value = "NEW"
If AgentForm.FolderList.ListIndex > 0 Then
destFolder = AgentForm.FolderList.List(AgentForm.FolderList.
ListIndex)
myItem.Move (myMailbox.folders(destFolder))
myItem.Close olSave
DoEvents
Next myItem
CloseRS AgentRS
Unload AgentForm
Set AgentForm = Nothing
When you are removing items from a collection never use For Each or count up
For loops since you are relying on an index that you are altering as you
remove the items. Use a count down For loop or a Do loop instead:
For i = myInbox.Items.Count To 1 Step -1
myItem = myInbox.Items(i)
' etc.
"John_Ba" <u54813@uwe> wrote in message news:9c31bd035d3e7@uwe...
> whether
> choose
> however
> USERCK
> myItem.Display
> AgentForm.Init = -1
> AgentForm.Show
> End If
> ListIndex)
> Else
> myItem.Close olSave
> End If
> DoEvents
> Next myItem
> CloseRS AgentRS
> Unload AgentForm
Ken,
Thanks very much, that was very helpfull. Pity it doesn't occur in more
programming examples of looping through items. I searched the web and MSDN
looking for a way to do this.
> ' etc.
> > whether
> [quoted text clipped - 46 lines]
> > Unload AgentForm
Commodore Unable to move message Using Outlook 3
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
mrmmickle1 UserProperties VBA to move message to another folder Outlook VBA and Custom Forms 7
T What code to use to move the custom field values to message body when sending e-mail ? Outlook VBA and Custom Forms 8
M Automatically move Outlook message to the specific folder when click on reply to all Using Outlook 4
M Error message: "Cannot move the items..." Using Outlook 2
M Outlook 2010 IMAP account message move behavior Using Outlook 15
mikolajek Outlook 2013 IMAP actions (message move / delete etc.) significantly delayed Using Outlook 0
D Error message - Cannot move the items.... Using Outlook 1
H move to folder rule corrupts message Using Outlook 3
A How do I move a message to a folder after forwarding ? Outlook VBA and Custom Forms 6
A How to catch Message Move Event. Outlook VBA and Custom Forms 10
H Move Selected emails to Local Drive Outlook VBA and Custom Forms 0
A Outlook 365 (OutLook For Mac)Move "On My Computer" Folder Items From Old To New Mac Computer Using Outlook 4
B Outlook 2019 Automatically move email after assigning category Using Outlook 4
M Move command Outlook VBA and Custom Forms 11
B Move emails from one account to another Outlook VBA and Custom Forms 2
J Dopey move - deleted profile Using Outlook 1
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
M Move to Folder Using Outlook 1
