Read Receipt Requested
W
wilhelmmt
I have created an auto Email capability in my Access database to run in
Outlook 2007. I need to add an automatic Read Receipt request to be sent with
each Email generated by the Access database. Is there a way to set this
request in the Access database code?
Dmitry Streblechenko
"Email generated" how exactly? Is that your code using the Outlook Object
Model?
Set the MailItem.ReadReceiptRequested property.
Dmitry Streblechenko (MVP)
"wilhelmmt" <wilhelmmt> wrote in message
news:D0C899D7-259F-4ABB-BE80-C07948AFB106@microsoft.com...
> with
C (Read, not read) receipt "subject" problem Using Outlook 8
S Duplicate Read Receipt Using Outlook 4
G Editing the Read Receipt Using Outlook 1
S Block read receipt when outlook is configured to Exchange server Using Outlook 0
R How to auto reply with read-receipt Outlook VBA and Custom Forms 2
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
M TO field on Read Page not resolving Using Outlook 3
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
