PR_MESSAGEFLAGS & Compose/Read - Inspector
Sebastian S.
Hello out there!
Is there any chance of setting the PR_MESSAGEFLAGS property (deleting
MSGFLAG_UNSENT) for an object? What I've read it should be possible just
before the first savechanges call. Is this for sure? Because it doesn't seem
to work here. C++ mapi code in a DLL.
The mainproblem is, that i use the display() method in an Add-In (2007, c#,
vsto3) which makes use of that DLL for item creation and manipulation.
Calling display() of the DLL-created Outlook.MailItem brings up an
compose-inspector but what I want is an read-inspector...
Cheers,
Sebastian
Dmitry Streblechenko
Outlook will not see your changes.
Do you create the message using OOM or MAPI?
Dmitry Streblechenko (MVP)
"Sebastian S." <SebastianS> wrote in message
news:1D2CC4C7-D5FD-473F-B3DA-489331D727E8@microsoft.com...
> Hello out there!
> seem
> c#,
> Cheers,
> Sebastian
Sebastian S.
Thanks for the reply.
Item creation with MAPI then display() with OOM.
Any idea how i can get a "read-inspector"?
Cheers,
Sebastian
> > Hello out there!
> > seem
> > c#,
> > Cheers,
> > Sebastian
Did you remove MSGFLAG_UNSENT bit from the PR_MESSAGE_CLASS proepty
immediately after creating the message and before saving it for the very
first time?
news:3EF5BF90-DFD8-4B6A-A0D9-E13EA87D625E@microsoft.com...
> Cheers,
> Sebastian
> > > Hello out there!
> > > just
> > > seem
> > > c#,
> >> > Cheers,
> > > Sebastian
Sebastian S.
Yes.
But I checked again... and solved the DEVELOPER_IQ_ERROR.
So all I needed was a "Dimitry said to" ;)
Thanks for your effort and sorry for stealing your time.
Cheers,
Sebastian
> first time?
> > Cheers,
> > Sebastian
> >> > Hello out there!
> >> > just
> >> > seem
> >> > c#,
> >> >> > Cheers,
> >> > Sebastian
R contact names does not display in compose emails using Outlook2013 Using Outlook 3
F Open Draft From Compose Window? Using Outlook 8
F Open Compose Only? Using Outlook 6
B Inherit from message compose form? Outlook VBA and Custom Forms 1
B Outlook message compose form Outlook VBA and Custom Forms 1
R (Outlook2003)Monitor change for "to" "cc" "bcc" on message compose dialog? Outlook VBA and Custom Forms 6
S E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
M Cannot read the calendar Using Outlook 9
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments Using Outlook 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
R Cannot read Chinese message after import Using Outlook 2
M Oh please read---> Extracting email web leads on to excel spread sheet Using Outlook 3
A Can't read my mails if they are on a folder... Using Outlook 0
M Unable to read HTML Using Outlook 2
J Cannot read incoming emails Using Outlook 2
P Custom field is read only Using Outlook 1
C (Read, not read) receipt "subject" problem Using Outlook 8
S iCloud Outlook Calendar is read only Using Outlook 1
Z Mark moved copies as "Read" Using Outlook 19
M Can't read invitations to appointments Using Outlook 1
